Speed at which a car on a banked curve will slide.
The discussion centers on calculating the maximum speed at which a car can navigate a banked curve without sliding off. The relevant parameters include a radius (R) of 200 meters, a banking angle (θ) of 10 degrees, and a coefficient of static friction (μs) of 0.60. The derived formula for maximum speed (v) is v > √(gR(tan(θ) + μs)/(1 - μs tan(θ))). A critical error in the initial calculation was identified, leading to an incorrect speed of 88.6 m/s, which was rectified by properly applying the static friction force. The corrected formula eliminates the erroneous tangent function in the friction term.
  • Understanding of Newton's laws of motion
  • Familiarity with circular motion dynamics
  • Knowledge of static friction and its role in motion
  • Ability to manipulate trigonometric functions in physics equations
  • Study the derivation of centripetal acceleration in circular motion
  • Learn about the effects of banking angles on vehicle dynamics
  • Explore the role of static friction in preventing sliding on curves
  • Investigate real-world applications of banked curves in road design
Physics students, automotive engineers, and anyone interested in the dynamics of vehicles on curved paths will benefit from this discussion.
SheldonG
If a car goes around a banked curve too fast, the car will slide out of the curve. Find an expression for the car speed [tex]v_{max}[/tex] that puts the car on the verge of sliding out. What is the value for R=200, [tex]\theta = 10[/tex], [tex]\mu_s = 0.60[/tex]?
a = v^2/r, F = ma.
Place the x-axis along the bank, and write the for equations for x and y:
[tex]\sum F_x = \frac{mv^2}{R}\cos\theta = mg\sin\theta + f_s[/tex]
[tex]\sum F_y = 0 = F_n - \frac{mv^2}{R}\sin\theta - mg\cos\theta[/tex]
It seems that the car should start to slide when
[tex]\frac{mv^2}{R}\cos\theta > mg\sin\theta + f_s[/tex]
Using [tex]fs = \mu_s F_n[/tex]
[tex]\frac{mv^2}{R}\cos\theta > mg\sin\theta + \mu_s\left(\frac{mv^2}{R}\sin\theta + mg\cos\theta\right)[/tex]
Solving for v:
[tex]v > \sqrt{\frac{gR(\tan\theta + \mu_s/\tan\theta)}{1-\mu_s\tan\theta}[/tex]
Unfortunately, the figure I get for v using R = 200, theta = 10, coefficient of static friction = 0.60 is much too high (88.6 m/s).
Could someone give me a hint about where I went wrong?
Thank you,
Sheldon
In this term [tex]\mu_s mg\cos\theta[/tex], if one divides by cos[itex]\theta[/itex], then one does not get a tan function, but simply
[tex]\mu_s mg[/tex]
So one would obtain
[tex]v > \sqrt{\frac{gR(\tan\theta + \mu_s)}{1-\mu_s\tan\theta}[/tex]
Thank you, Astronuc. I am in your debt. What a stupid error :-)
Sheldon
  • · Replies 24 ·
  • · Replies 97 ·
