Electric Field due to a charged conducting finite cylindrical shell.
The discussion centers on calculating the electric field and potential of a charged conducting finite cylindrical shell, specifically addressing the use of Gauss's law. It is established that Gauss's law cannot be applied to finite cylinders, which complicates the calculation of the electric field between two conducting cylindrical shells. The derived electric field formula is given as (charge/2*Pi*Length*epsilon_0*radius), leading to a potential that diverges to infinity at infinity. The capacitance formula is confirmed as C=(2*Pi*epsilon_0*Length)/log((second radius)/(first radius)).
  • Understanding of Gauss's Law and its limitations
  • Familiarity with electric fields and potentials in cylindrical coordinates
  • Knowledge of capacitance calculations for cylindrical capacitors
  • Proficiency in calculus, particularly integration of logarithmic functions
  • Study the application of Gauss's Law for infinite versus finite geometries
  • Learn about electric field calculations for cylindrical capacitors
  • Explore the derivation of potential from electric fields in cylindrical systems
  • Investigate the implications of potential divergence in electrostatics
Physics students, electrical engineers, and anyone involved in electrostatics or capacitor design will benefit from this discussion.
ed2288
Hi everyone. I'm having a bit of trouble with finding an electric field. Basically, I'm trying to understand the formula for a cylindrical capacitor, so the method involves integrating the field between two conducting cylindrical shells. Firstly can Gauss's law be used in this case, because the cylinder is finite? Are the field lines all radial, even at the very end of the cylinder? If so, this leads to my next problem. The field turns out to be:
So, when you integrate this to obtain the potential, you will end up with a natural logarithm, meaning at infinity, the potential is infinity!? I'm sure this is wrong but I just can't see where the error is. Any help would be greatly appreciated!
The Gauss theorem CANNOT be used for finite charged cylinder.
Ok then, but how can you calculate the field inbetween the two finite cylinders? You need the field so you can integrate it to get the potential, which you can then use to calculate the capacitance, which, I'm told, turns out to be
