How Fast Must a Salmon Jump to Clear a 1.9m Waterfall?
  • Thread starter Thread starter kkumar
    Dimension Motion
The discussion revolves around determining the minimum vertical velocity a salmon must achieve to clear a 1.9m waterfall. The problem involves concepts from kinematics, particularly the equations of motion under gravity.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of kinematic equations, questioning the setup of initial and final velocities. Some express uncertainty about the calculations and the correct interpretation of the equations.
There is an ongoing exploration of the correct equations to use, with some participants suggesting corrections to the original poster's approach. Multiple interpretations of the problem are being discussed, and guidance has been offered regarding the use of squared velocities in the equations.
Some participants express urgency in needing assistance, indicating a time constraint. There are also references to other physics problems involving energy and motion, suggesting a broader context of learning in mechanics.
kkumar
In its final trip upstream to its spawning territory, a salmon jumps to the top of a waterfall 1.9m high. What is the minimum vertical velocity neeeded by the salmon to reach the top of the waterfall?
This uestion has no velocity so, do you think that final velocity is Zero...
solution:
Vfinal y=0m/s
Vfinal X=at as initial velocity for x is 0
dy=1.9m
V final y=v initial y+2ady
0=v initial y+2*(-9.8)*1.9
V initial = 37.24m/s
Please help me in solving this uestion
Hi kkumar,
I believe you have the equation wrong. The velocities are squared, so it is:
[tex] v_y^2 = v_{oy}^2 + 2 a_y(\Delta y)[/tex]
and so you need to take a square root to get your final answer.
Thanks for your help in soiving my problem.
Hello I need help with this question as soon as possible. Can anyone help me out?
1) Consider the frictionless roller coaster. A car 12000kg car starts at rest from point A The height of point A is 95 m and comes down to point B which is at height of 65m and then bounce back again to point C which is at height 65m again and then bounce back to point D which is 25 m from the bottom and then rolls on the floor and stops at a point E.
A) calculate the total energy of the system
B) the speed of the car at point B
C) the force that must be applied to bring it to a stop at point.
D) The work done to bring it to a stop at point E.
I have worked it out but not sure if it is right.
Thank in advance for working on it
alphysicist said:
Hi kkumar,
hi alphysicist i need ur help with dis ques--> in its final trip upstream to its spawning territory, a salmon jumps to the top of a waterfall 1.9 m high. what is the minimum vertical velocity needed by the salmon to reach the top of the waterfall?
Hi hardlyfe,
What have you tried so far? What equation have you used, what numbers are you using, and what did you get for an answer?
so i tried solving it by ur formula the answer that i got is 6.1 m/s for Viy. but I am not sure if dis answer is rit or wrong...
thnx a lot for replyin ma ques..
That looks right to me. Does it not seem right to you?
thnx anywaz...
  • · Replies 38 ·
