Desperate college student needs help in double integral
The discussion focuses on using double integrals to derive formulas for the volume of a right circular cone and a spherical cap, as well as the surface area of a spherical cap. The volume of a cone is expressed as (πR²H)/3, while the volume of a spherical cap is (πH²(3R-H))/3, and its surface area is 2πRH. The participant struggled to incorporate height (H) into the double integral calculations, particularly when using polar coordinates for the cone's volume.
  • Understanding of double integrals in calculus
  • Familiarity with polar coordinates
  • Knowledge of geometric formulas for volume and surface area
  • Concept of integrating over bounded regions in the xy-plane
  • Study the application of double integrals in deriving geometric formulas
  • Learn how to convert Cartesian coordinates to polar coordinates
  • Explore the concept of height as a function in double integrals
  • Investigate examples of calculating areas and volumes using double integrals
Students in calculus, particularly those studying double integrals, and anyone seeking to understand the geometric applications of integration in deriving volume and surface area formulas.
marik
here is the problem I couldn't solve, anyone got any idea please help me.
thank you very much in advance
1) use double integrals to derive the given formula for the volume of a right circular cone of radius R and height H. the volume of a cone is given by the formula
(pi*R^2*H)/3
I tried to use polar coordinates, but what is troubling me is that I couldn't get H into the formula.
2) use double integrals to derive the given formula for the volume of a cap of a sphere of radius R and height H where 0<H<R. (the cap of a sphere is the portion of the sphere bounded below by the plane z=R-H and bounded above by the plane z=R). the volume of a cap of a sphere with radius R is given by the formula
( pi*H^2*(3R-H))/3
same problem, I couldn't get H into the formula from double integration
3) use double integrals to derive the given formula for the surface are of a cap of a sphere of radius R and height H where 0<H<R. (the cap of a sphere is the portion of the sphere bounded below by the plane z=R-H and bounded above by the plane z=R). the surface area of a cap of a sphere with radius R is given by the formula
2*pi*R*H
4) use a double integral to calculate the area for the region in xy-plane bounded by y=H, y=0, x=0, and the line containing the point (a,0), and (b,H) where a,b,H>0 and b<a.
5) use double integral to calculate the area for the sector in the polar plane bounded by the ray thetha=0 and thetha=R>0 and the circle x^2+y^2=R^2 in the first quadrant.
any help on any problem is deeply appreciated
For #1, using polar coordinates is a good idea. You should be able to see that the height , i.e. z, of a part of the cone is a function of r. This function will have H in it. If you're uncertain how to find it, you should be able to see that its is linear and what are its values when r=0 or r=R.
  • · Replies 16 ·
