| Thread Closed |
Joule Heating, Calculating Filament Resistance |
Share Thread | Thread Tools |
| May1-08, 08:19 PM | #1 |
The experiment is joule heating and I'm trying to calculate the filament resistance.
1.) mass of the calorimeter cup 49.5g specific heat of the aluminum cup: 0.22 cal/kg*K mass of calorimeter cup w/ water 232.5g initial water temp. 20.5 C voltage across heater 7.3V current through heater 5A final water temp 32.7 C time interval 10mins calculated filament resistance = ? ΔQ = mcΔT ; have to use this twice, mass and heat capacity of water + mass and heat capacity of the aluminum calorimeter cup U = I squared * Resistance * time 3.) I have no clue where to go :| I've attempted numerous times but I haven't come out with a resistance anywhere close to what I should be getting. can anybody help me out ? |
| May1-08, 08:42 PM | #2 |
if any1 can log onto aol instant messenger or mirc, post your screename or an irc server/channel name, so that we can chat :) thanks
| May2-08, 10:33 AM | #3 |
Recognitions:
Hi reaxn,
Please post some details of what you have done (the numbers you used in the equations and your final answer). |
| May2-08, 12:33 PM | #4 |
ok i subsituted in all the values and came out with a Q of 9897.1
i interchanged Q and U and plugged in U = I^2*R*t i used 5 for I and time 600s? is that correct or should i have used 10 mins? the R came out to be .660 once i solved for R seems very wrong for some reason :( |
| May2-08, 01:04 PM | #5 |
Recognitions:
Yes, it should be 600 seconds since you're using 5 amps( and an amp is a coulomb/second).
However, I was more interested in the numbers you used to get the Q value, because some of your numbers seem like they might have problems. For example, you have the specific heat of aluminum as 0.22 cal/(kg*K), but I think that is not right; I think it needs to be 0.22 cal / (g*K). By the way, do you know your answer is wrong? What do you think it should be? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Joule Heating, Calculating Filament Resistance
| Resistance of a heating element? | Introductory Physics Homework | 22 | ||
| calculating power of heating element | Classical Physics | 22 | ||
| Calculating air resistance | Introductory Physics Homework | 3 | ||
| The Hot Resistance Of the filament | Introductory Physics Homework | 12 | ||
| Short Circuit, Joule Heating ... | Introductory Physics Homework | 0 | ||
