How Do You Calculate the Frequency of a Tuning Fork Using a Resonance Tube?
The frequency of a tuning fork can be calculated using a resonance tube submerged in water, where the length of the air column, L, is adjusted to find resonant frequencies. The smallest resonant length, L, is 8.00 cm, and the speed of sound in air is given as 330 m/s. The formula V = f * λ is essential, where V is the speed of sound, f is the frequency, and λ is the wavelength. For the next two harmonics, the values of L can be determined using the relationship L = n * (V / 4f), where n is the harmonic number.
  • Understanding of wave mechanics and resonance
  • Familiarity with the speed of sound in air (330 m/s)
  • Knowledge of harmonic frequencies and their calculations
  • Ability to manipulate formulas involving frequency and wavelength
  • Calculate the frequency of the tuning fork using the formula f = V / (4L)
  • Determine the lengths for the next two harmonics using L = n * (V / 4f)
  • Explore the concept of standing waves in open tubes
  • Research the effects of temperature on the speed of sound in air
Students studying physics, educators teaching wave mechanics, and anyone interested in acoustics and resonance phenomena.
lettertwelve
The frequency of a tuning fork can be found by the method shown in Figure 13-24. A long tube open at both ends is submerged in a beaker of water, and the vibrating tuning fork is placed near the top of the tube. The length of the air column, L, is adjusted by moving the tube vertically. The sound waves generated by the fork are reinforced when the length of the air column corresponds to one of the resonant frequencies of the tube. The smallest value for L for which a peak occurs in sound intensity is 8.00 cm. (Use 330 m/s as the speed of sound in air.)
(a) What is the frequency of the tuning fork?
______Hz
(b) What is the value of L for the next two harmonics?
______m
______m
V/4L ?
i tried the V/4L for part b, but nothing works.
i don't know where to even start
Hi lettertwelve,
What numbers did you use in your attempts for part b? Did you find the frequencies of the next two harmonics?
Not only what numbers did you use, but did you include units in the calculation?
What did you get when you calculated V/4L, and how do you know (or why do you think) it is wrong?
9K
31K
