Thermodynamics refrigerator problem
The discussion focuses on the thermodynamics of refrigerators, specifically the work done to transfer heat from a lower temperature body to a higher temperature reservoir. It clarifies that in a refrigerator, work is performed by compressing a gas, which raises its temperature and releases heat to the hot reservoir. Upon expansion, the gas absorbs heat from the cool reservoir, demonstrating the principles of heat transfer and work in thermodynamic cycles. Additionally, the conversation touches on the concept of reversible processes, emphasizing that while energy dissipation occurs, the ideal Carnot engine minimizes this loss.
  • Understanding of thermodynamic cycles
  • Familiarity with the Carnot engine concept
  • Knowledge of gas laws and behavior under compression and expansion
  • Basic principles of heat transfer
  • Study the principles of thermodynamic cycles in detail
  • Learn about the Carnot engine and its efficiency calculations
  • Explore the laws of thermodynamics, particularly the first and second laws
  • Investigate real-world applications of refrigeration and heat pumps
Students of physics, engineers in thermodynamics, and professionals involved in refrigeration technology will benefit from this discussion.
daemonakadevil
Hi Everyone!
I have couple of questions this time! :D
1) In refrigerator we say that we have to do some work on system to flow heat from lower temp body to higher temp reservoir , so if temp1 > temp2
then temp2 + work = temp1 now what i want to ask is that
what kind of work we do on system to absorb heat? e.g we do expansion on system
please tell taking example of pistons , it makes me pretty clear!
2) if we say that reversible process why we say that heat should be flown infinety slowly , no dissipation of enerygy etc??
Thanks a lot for taking your preciuos time for me!
please mods move this thread General physics , thanks!
daemonakadevil said:
Hi Everyone!
I am not sure what you are asking. No work needs to be done for a system to absorb heat. Heat flows naturally from higher temp. body to a lower temp. body. In a refrigerator, this occurs by compressing a gas (raising its temp. and releasing heat to the hot reservoir) and then letting that compressed gas expand and do work (lowering its temperature and absorbing heat from the cool reservoir).
Energy is dissipated in a reversible process. The ideal Carnot engine will dissipate less energy than any other engine, but it will never reach 100% efficiency.
AM
  • · Replies 20 ·
  • · Replies 36 ·
10K
