Calculating Force Exerted by Man on 380kg Piano Down an Incline
  • Thread starter Thread starter inflames829
    Force
The problem involves a 380kg piano sliding down a 27-degree incline, where a man is exerting a force to prevent it from accelerating. The effective coefficient of friction is given as 0.40, and the task is to calculate the force exerted by the man.
  • The original poster expresses confusion about using F = ma and whether the angle of the incline is necessary for calculating the force. Some participants suggest starting with resolving forces into components parallel and normal to the incline, and the use of a free body diagram is recommended.
Participants are exploring different interpretations of the problem, particularly regarding the resolution of forces and the implications of the incline. Guidance has been offered on how to approach the problem, including the importance of considering gravitational force components and friction.
There is an emphasis on the lack of acceleration in the system, which influences the approach to equating forces. The discussion also highlights the need to consider the coordinate system in relation to the incline.
inflames829
A 380kg piano slides 3.5m down at 27 degree incline and is kept from accelerating by a man who is pushing back on it parallel to the incline. The effective coefficient of friction is 0.40. Calculate the force exerted by the man
Im confused with this because i think i have to use F =ma but I am not sure because i don't know if i have to use the angle of incline as well to work out the force. Can someone please give me some hints or help
A good place to start is resolving the forcing acting into their components that are parallel and normal to the incline. A free body diagram always helps.
what do you mean by resolving the forces acting into their components that are parallel and normal to the incline
resolving the force means making all the components of various forces on that object..since there's no acc u can take the force to b zero and thus equate the forces in opp direction..gud luck!
If the man was not pushing against the piano, it would accelerate down the slope. The direction of this acceleration (down the slope) is usually the best choice to choose your coordinate system.
In this question, the coordinate system is therefore slightly skewed in relation to the 'ground'.
The gravitational force acting on the piano however is directed straight 'into the ground' and is therefore not aligned with the coordinate system.
Whenever you see this, you can 'split' the force into two components, one along the y-axis and one along the x-axis.
The component of the gravitational force that acts along the line of the slope will be the force that actually makes the piano move.
You can find the size of this force by using some trigonometry (you know the angle of the slope).
Finally, don't forget that there is also friction and the force of the man pushing back that is stopping the piano.
