Proving/Disproving Series Transformation Properties
The discussion centers on the properties of series transformations, specifically examining the conditions under which two series, \(\sum a_n\) and \(\sum b_n\), can be related through rearrangement and convergence. It is established that if \(\sum |b_n|\) converges, then \(\sum b_n\) is absolutely convergent, leading to the conclusion that \(\sum a_n\) must equal \(\sum b_n\). This directly contradicts the second condition, \(\sum b_n = 2 + \sum a_n\), thus proving that such series cannot exist under the given constraints.
  • Understanding of series convergence, particularly absolute convergence
  • Familiarity with rearrangement of series
  • Knowledge of mathematical notation for series and summation
  • Basic principles of real analysis
  • Study the properties of absolutely convergent series in real analysis
  • Explore the Riemann series theorem and its implications on series rearrangement
  • Investigate examples of series that demonstrate convergence and divergence
  • Learn about the implications of series transformations in functional analysis
Mathematicians, students of real analysis, and anyone interested in the properties of series and convergence in mathematical theory.
daniel_i_l
Prove or disprove:
There exist series [tex]\sum a_n[/tex] and [tex]\sum b_n[/tex] so that:
1) you can get [tex]b_n[/tex] by rearranging the elements of [tex]a_n[/tex]
2) [tex]\sum b_n = 2 + \sum a_n[/tex]
3) [tex]\sum |b_n| = 2 \sum a_n[/tex]
(all the series converge to finate values)
From (1) I know that [tex]\sum |b_n| = \sum |a_n|[/tex] but I can't see how can to continue from here, can someone point me in the right direction?
Thanks.
You can't say that all series mentioned converge, because if [tex]\sum |b_n|[/tex] converges then the series is absolutely convergent which means that any reordering of the original series [tex]\sum b_n[/tex] converges to the same value, which implies that [tex]\sum a_n = \sum b_n[/tex] by virtue of (1). That means that (1) contradicts (2). So I have to say that it's impossible. But I could be wrong.
How do you know that rearranging the elements in an absolutly converging series doesn't change their value?
EDIT: Oh, it's easy to see that that's true if you split up each of the series into positive and negative "sub-series".
Thanks for your help.
