Why Is the Electric Field Not Multiplied by 2 in This Capacitor Calculation?
The discussion clarifies the calculation of capacitance for a parallel-plate capacitor, specifically addressing the electric field's role in determining potential difference. The electric field is defined as \(\frac{\sigma}{2\varepsilon}\), leading to a potential \(V = \frac{\sigma}{2\varepsilon}d\). The confusion arises from the application of superposition in textbooks, which does not require dividing the electric field by 2 when considering the potential between two plates. The final understanding emphasizes that the electric field is influenced by the configuration of the capacitor, particularly when comparing it to cylindrical geometries.
  • Understanding of electric fields and potential difference
  • Familiarity with capacitance concepts and formulas
  • Knowledge of Gaussian surfaces in electrostatics
  • Basic principles of superposition in electric fields
  • Study the derivation of capacitance for parallel-plate capacitors
  • Explore the concept of electric field superposition in different geometries
  • Learn about Gaussian surfaces and their applications in electrostatics
  • Investigate the differences between cylindrical and parallel-plate capacitor configurations
Students studying electromagnetism, physics educators explaining capacitor concepts, and anyone seeking to deepen their understanding of electric fields and capacitance calculations.
Niles
[SOLVED] Capacitance and electric fields
I want to find the capacitance of a parallel-plate capacitor consisting of two metal surfaces og area A held a distance d apart.
First I find the electric field, which I know is [tex]\frac{\sigma }{{2\varepsilon }}[/tex]. Then I use that the potential is the line integral from minus-charge plate to positive-charge plate of electric field, so
[tex]V = \frac{\sigma }{{2\varepsilon }}d[/tex]
But in my book they do not divide by 2. This is because they have used superposition, which is OK - I agree with that.
Next, we consider the following:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capcyl.html#c2
Here they have used the electric field for |one| cylinder, they have not used superposition. This I do not agree with - we are still between the cylinders, so why do we not multiply by 2 here?
Oh, right.. because the charge inside our gaussian surface is the charge coming from the "inside-cylinder"...
I get it now. Thanks
Actually the electric field is not between two cylinders, but it is in between a cylinder and a pipe, so it is not the same case as two parallel capacitors.
  • · Replies 23 ·
  • · Replies 16 ·
