The puzzling discovery of a motor made from liquid film
The Iranian physicists at Sharif University of Technology discovered a novel phenomenon where a thin film of water rotates when subjected to two perpendicular electric fields. This effect, termed a "liquid film motor," occurs without chemical reactions and is controlled by varying the electric fields' angles and directions. The rotation is attributed to the intrinsic dipole moment of polar liquids, ruling out convection and ion movement as causes. This discovery has significant implications for industrial applications in microfluidic devices for mixing.
  • Understanding of electrohydrodynamics
  • Familiarity with polar and non-polar liquids
  • Knowledge of electric field applications in fluid dynamics
  • Basic principles of thin film physics
  • Research the principles of electrohydrodynamics in thin films
  • Explore applications of microfluidic devices in industrial mixing
  • Study the effects of electric fields on polar liquids
  • Investigate the role of intrinsic dipole moments in fluid dynamics
Physicists, engineers, and researchers interested in fluid dynamics, electrohydrodynamics, and the development of microfluidic technologies.
SF
Here’s an interesting effect discovered by a group of Iranian physicists at Sharif University of Technology in Tehran, Iran (it’s not often we hear from these guys).
They placed a thin film of water in a square cell and applied two perpendicular electric fields. One was an external electric field. For the other, they used two copper electrodes to generate a voltage across the cell like an electrolysing cell (although no chemical reaction took place).
So they had a pair of electric fields at right angles acting on this thin film.
The unexpected result is that the film of water begins to rotate. The team has a number of movies of the effect on its website. They call it a liquid film motor and it’s a quite extraordinary effect. At one point they divide their cell into nine smaller ones and the liquid in each cell rotates in exactly the same way.
The question is: what’s causing the rotation? The team can easily control the direction and speed of rotation by varying the relative angle and direction of the electric fields, which rules out the possibility that convection is causing the rotation (something that is seen when a field is applied to some thin films of liquid crystals). Neither does adding salt to water change the effect, ruling out the possibility that ion movement directs the flow.
The rotation occurs in polar liquids but not in non-polar ones so the intrinsic dipole moment of the molecules seems to be crucial. People have been observing the electrohydrodynamics of various types of thin films for a good few years but nobody has seen anything like this. Just what’s going on remains a mystery.
But the puzzle shouldn’t overshadow what looks like an important discovery that could have widespread industrial application in microfluidic devices for mixing.
Ref: arxiv.org/abs/0805.0490: A Liquid Film Motor
Src: http://arxivblog.com/?p=401
Interesting, for sure. One hint may be in the final sentence:
"Any efforts to rotate a bulk of liquid was defeated. The fact that only thin liquid films rotate notably and that rotation can not be observed in relatively thick films even at high fields, implies that this phenomenon is a surface effect."
It's not clear from the paper if they tried doing this with a pure fluid- no mention was made of how to keep the fluid uncontaminated.
9K
  • · Replies 21 ·
  • · Replies 19 ·
19K
