| Thread Closed |
the XRD pattern of Zinc oxide and zinc oxide in acrylic acid !! |
Share Thread | Thread Tools |
| May7-08, 10:46 PM | #1 |
I did XRD analysis of zinc oxide, and its peaks are at 31.7, 34.4, 36.2, 47.5, 56.6, 62.9 and 67.9 (2-theta degree).
further, I did XRD of zinc oxide dispersed in acrylic acid/IPA. but it's wierd !! Why I could got some peaks at 21.6, 27.2, 32.7, 38.4, 44.1, 50.0, 62.1 and 68.5 (2-theta degree), but these peaks are totally different from the peaks of pure zinc oxide ??! Is it cause of the crystalline has been changed or destroyed ? thanks for your teaching !! |
| May8-08, 08:53 AM | #2 |
Two big concerns with the medium:
1. Acrylic acid polymerizes pretty easily upon radiation. I would hardly be surprised if you've now got significant amounts of poly-acrylic acid in the medium, which may be producing the extra peaks. 2. What are the purity levels of AA/IPA? |
| May12-08, 01:52 AM | #3 |
I dispersed ZnO particles in AA/IPA mixture which is 50:50 ratio.
And, I add 0.1g ZnO into 1g AA and 5g IPA, then did polymerization; but i could get the apparent peaks of ZnO particles in XRD analysis (there is no any peak )!! that's wierd !! |
| May15-08, 08:27 AM | #4 |
Could you have formed an acrylic/zinc soap? When you polymerized the AA did you form a gel or did a solid ppt? If you are isolating a ppt, perhaps the zinc component remains in the IPA?
| Thread Closed |
| Thread Tools | |
Similar Threads for: the XRD pattern of Zinc oxide and zinc oxide in acrylic acid !!
| Zinc and Hydrochloric Acid | Chemistry | 9 | ||
| How to convert boric acid to boric oxide | Biology, Chemistry & Other Homework | 5 | ||
| Zinc-64 decay? | High Energy, Nuclear, Particle Physics | 4 | ||
| did zinc react with zinc sulphate solution? | Chemistry | 2 | ||
| Pentacoordination of Zinc? | Chemistry | 5 | ||
