Thread Closed
Beam bending
Share Thread Thread Tools
May8-08, 07:22 AM   #1
Beam bending
If you have two beams, not attatched to each other, placed on top of each other in 3 point bending simply supported, what do you do to find the first moment of area and moment inertia of the two beams.
Thanks
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
May8-08, 10:30 AM   #2
Recognitions:
If you assume that they will always stay in contact, then the parallel axis theorem is what you need.
http://hyperphysics.phy-astr.gsu.edu...parax.html#pax
May8-08, 11:22 AM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi Fred,
I think what ttlg is asking is if the two beams are simply sitting on top of each other such that there can be no transverse shear between the two (like a leaf spring on a car). The two beams, stacked one on top of the other, are then simply supported at the ends and loaded in the center with a verticle force. In that case, since there's no transverse shear between the two (ie: the beams act independantly) the parallel axis theorem doesn't apply to the beams as a set. In this case, the load acting on the beams can simply be split 50/50 between the two beams (each beam supports 1/2 the load).
May8-08, 03:57 PM   #4
Recognitions:
Beam bending
Q,
The loads can be split the way you mention, but to find the area MOI of the assembly, i.e. the composite section, one needs to use the parallel axis theorem. I am using the interface between the two beams as the neutral axis (with no shear between the two as you mentioned). From there take the two individual beams' respective area MOIs and use the parallel axis theorem to calculate the overall area MOI.
May9-08, 10:56 AM   #5
ok, thanks for your help
May12-08, 09:23 AM   #6
Recognitions:
Quote by FredGarvin View Post
Q,
Quote by QGoest
Looking at Q's comments about the shear stress...he's right on that. The MOI is simply two times the individual MOIs.
Thread Closed
Thread Tools
Similar Threads for: Beam bending
Thread Forum Replies
beam bending Classical Physics 2
beam bending Engineering, Comp Sci, & Technology Homework 1
bending for beam -- deflection Engineering, Comp Sci, & Technology Homework 5
Beam Bending & Stress Mechanical Engineering 1
