What is the Antiderivative of 5\sqrt{}x?
The discussion revolves around finding the antiderivative of the function involving a square root, specifically focusing on the expression 5√x and its definite integral from 1 to 7.
  • Participants explore the application of the power rule for integrals and discuss the correct interpretation of the integral involving 5/√x. There is an attempt to clarify the setup of the definite integral and the correct form of the integrand.
Some participants have provided guidance on using the power rule for integrals, while others are questioning the original setup and calculations. There is an ongoing exploration of the correct approach to finding the antiderivative.
There is a noted confusion regarding the expression of the integrand and the application of the Fundamental Theorem of Calculus. Participants are addressing potential misunderstandings in the setup of the problem.
jimen113
the antiderivative for 5[tex]\sqrt{}x[/tex]
It almost looks like the derivative of the function [tex]\sqrt{}x[/tex]
[tex]\int 5\sqrt{x} = \int 5x^{1/2}[/tex]
So just use the power rule for integrals.
revised
the actual problem is:
Evaluate the definite integral [tex]\int^{7}_{1}[/tex] 5/[tex]\sqrt{}x[/tex]
using the power rule I got:
5[(x^3/2)/(3/2)] evaluating them at the end points 1 and 7, the answer I get after using FTC II is:-58.400 and is incorrect.
What am I doing wrong? please help
Do you mean [tex]\int_1^7 \frac{5}{\sqrt{x}} \ dx[/tex]?
If so, then x^(3/2) shouldn't be part of your answer.
Yes (to part one)
then how should I find the antiderivative? for 5/[tex]\sqrt{}x[/tex]
You must first find the antiderivate for [tex]x^{-\frac{1}{2}}[/tex]. Use the power rule for integrals as Feldoh said.
Thanks for your help!
  • · Replies 105 ·
13K
