Energy Conservation and Friction
The problem involves a 2.00 kg package released on a 53.1-degree incline, moving towards a spring with a force constant of 120 N/m. The coefficients of friction are provided, and the questions focus on the speed of the package before reaching the spring, the maximum compression of the spring, and how far the package rebounds up the incline.
  • Mixed
  • Participants discuss energy conservation principles, including kinetic and potential energy, as well as work done by friction. There are attempts to calculate forces and energy changes, with some questioning how to determine the normal force and the height of the incline.
Some participants have provided calculations and attempted to solve parts of the problem, while others have raised questions about the application of friction forces and the correct interpretation of energy equations. There is no explicit consensus on the correctness of the approaches taken.
Participants are navigating the complexities of frictional forces on an incline and the implications of energy conservation in this context. There are indications of potential misunderstandings regarding the application of static versus kinetic friction.
akhila1489
A 2.00 kg is released on a 53.1degree incline, 4.0 m from a long spring with force constant 120 N/m that is attached at the bottom of the incline. The coefficients of friction between the package and the incline are static friction constant = 0.40, and kinetic friction constant= 0.20. The mass of the spring is negligible.
a)what is the speed of the package just before it reaches the spring.
b)what is the maximum compression of the spring?
c)the package rebounds back up the incline. How close does it get to its initial position?
K1+U1+Wother = K2+U2
Wother= -fs
s is 4m, the distance it needs to get to the spring.
f= fk + fs
fk= 0.20n
fs=0.40n
how do i get n? (n=wcos53.1??)
in that case f= fs+fk= [0.20(2*9.8)(cos53.1)]+[0.40(2*9.8)(cos53.1)]=7.06
f= [-(K2+U2)-(K1+U1)]/s
f=[-(0+mgh)-(0.5mv^2 + 0)]/4 = 7.06
28.24=(-2*9.8*h)-(0.5*2*v^2)
to solve for v, we need h, is h simple sin53.1?
(*i made a diagram as well, but it isn't allowing me to post it...*)
i got part c by doing the following
let x = max compression
U1-fs=0.5kx^2
s= 4+x​
k=120N/m​
2*9.8*(4+x)sin53.1-2.35(4+x)=60x^2
solving the quadratic gives you x=1.06m.
is this remotely correct?
Welcome to PF!
Hi akhila1489! Welcome to PF! :smile:
Yes, h is 4sin53.1.
but I can't follow the rest of what you've done for part a). :confused:
Just use KE + PE = constant! :smile:
Hi akhila1489,
Wother= -fs
f= fk + fs
You don't want to add the kinetic and static frictional forces. You need to decide which one applies to the case of a object sliding down an incline plane, and use that.
fk= 0.20n
fs=0.40n
I don't think this follows from your original equation. Your original equation was
[tex] K_1+U_1+W = K_2+U_2[/tex]
so this means that K2 and U2 are the final values, and K1 and U1 are the intial values. You also had W= -f s. So when you solve for f, I think you have a sign error; it should be:
[tex] f=[-(K_2 +U_2) + (K_1 + U_1)]/s[/tex]
(Also, later you plug in final values for K1 and U1, and initial for K2 and U2.)
  • · Replies 33 ·
  • · Replies 27 ·
  • · Replies 22 ·
  • · Replies 17 ·
