Proving Induction: Sum 1 to n of 1/√i ≥ √n
  • Thread starter Thread starter dtl42
    Induction
The problem involves proving by induction that the sum from 1 to n of \( \frac{1}{\sqrt{i}} \) is greater than or equal to \( \sqrt{n} \). This falls within the subject area of mathematical induction and inequalities.
  • The original poster attempts to verify the base case and expand the sum, but struggles to find a useful direction. They inquire about the implications of adding \( \frac{1}{\sqrt{n+1}} \). Other participants suggest focusing on the inequality after the induction assumption and combining terms to facilitate the proof.
Participants are actively engaging with the problem, exploring different aspects of the induction proof. Some guidance has been offered regarding the manipulation of terms, but there is no explicit consensus on the next steps or a complete resolution of the problem.
The discussion is constrained by the requirement to prove the inequality through induction, and participants are navigating the complexities of combining terms and verifying assumptions.
dtl42
Prove by induction. The sum from 1 to n of [tex]\frac{1}{\sqrt{i}}[/tex] [tex]\geq[/tex] [tex]\sqrt{n}[/tex].
none.
I verified the base case, and all of that, I just can't get to anything useful. I tried expanding the sum and adding the [tex]\frac{1}{\sqrt{n+1}}[/tex] but it didn't come to anything useful.
Thanks
What have you gotten after adding the [itex]1/\sqrt{n+1}[/itex] ? What would you like the numerator of the fraction to be after combining?
after the induction assumption you have to prove the inequality:
[tex]\sum_{i=1}^n {\frac{1}{\sqrt{i}}}+\frac{1}{\sqrt{n+1}} \geq \sqrt{n+1}[/tex]
given that [tex]\sum_{i=1}^n {\frac{1}{\sqrt{i}}} \geq \sqrt{n}[/tex]
Assuming [tex]\sum_{i=1}^n {\frac{1}{\sqrt{i}}} \geq \sqrt{n}[/tex]. [tex]\sum_{i=1}^n {\frac{1}{\sqrt{i}}}+\frac{1}{\sqrt{n+1}} \geq \sqrt{n}+ \frac{1}{\sqrt{n+1}}[/tex]
Adding those, [tex]\sqrt{n}+ \frac{1}{\sqrt{n+1}}=\frac{\sqrt{n^2+ n}+1}{\sqrt{n+1}}[/tex]
that's what you want if [tex]\sqrt{n^2+ n}+ 1\ge \sqrt{n+1}[/tex] and that should be easy to prove.
  • · Replies 19 ·
  • · Replies 24 ·
