Maximum Acceleration of Stacked Blocks on Vertical Spring
The problem involves two stacked blocks on a vertical spring, with the goal of determining the maximum acceleration of the blocks while maintaining contact. The context includes concepts from mechanics, specifically relating to forces, acceleration, and spring dynamics.
  • Participants discuss the forces acting on the top block, including gravity and the spring force. There are attempts to formulate equations using Newton's second law and to clarify the conditions under which the blocks lose contact.
The discussion is ongoing, with participants exploring the relationship between the forces acting on the blocks and how they relate to the maximum acceleration. Some guidance has been offered regarding the normal force and its role in the equations being developed.
Participants are considering the implications of the spring constant and the masses of the blocks, as well as the conditions under which the top block will lose contact with the bottom block. There is a focus on understanding the forces involved without reaching a final conclusion.
fiziksfun
An 5 kg block is fastened to the top of a vertical spring (perpendicular to the floor) with a spring constant of 1000 N/m. A 3 kg block sits on top of the 5 kg block.
The springs are pushed down so that they oscillate.
I need help finding the magnitude of the maximum acceleration the blocks can obtain while still remaining in contact. I have no idea where to begin.
Any suggestions!? Help please!
HINT: Consider the forces acting on the 3kg block, which force will be zero when the blocks lose contact?
Ok so when the blocks lose contact, the force of the spring-mass will be equal to the force of gravity on the 3 kg block.
M(3)*a=-2mg, is this correct?
You've still not answered my first question. What are the forces acting on the top block?
The forces acting on the block are gravity and the force of the spring, correct? Or friction??
Correct, but what I was trying to get at is that the force of the spring acts through the normal force exerted on the block. Hence, the net force acting on the block is [itex]N - mg[/itex]. Can you now use this information to write an equation using Newton's second law?
ma = N - mg
but what is the magnitude of the normal force ??!? kx !?
fiziksfun said:
ma = N - mg
Correct! And what do you know about the normal force when the block leaves the surface of the 5kg block?
  • · Replies 27 ·
11K
  • · Replies 18 ·
