Why Is Ran(A - λI) an Invariant Subspace of A?
The discussion revolves around the concept of invariant subspaces in the context of linear algebra, specifically focusing on the range of the operator \( A - \lambda I \) and its relationship to the matrix \( A \). Participants explore the definitions and implications of invariant subspaces, questioning the conditions under which the range of \( A - \lambda I \) is considered invariant under \( A \).
  • Some participants express confusion about why elements of \( \text{Ran}(A - \lambda I) \) are also in the range of \( A \).
  • One participant attempts to clarify that \( A((A - \lambda I)V) \) results in another element of \( \text{Ran}(A - \lambda I) \), suggesting that this demonstrates invariance.
  • Another participant questions the interpretation of the statement that \( \text{Ran}(A - \lambda I) \) is a subspace of \( A \), seeking clarity on whether it implies linear combinations of columns of \( A \).
  • There are assertions that the range of \( A - \lambda I \) being invariant does not necessarily mean it is in the range of \( A \), with examples provided to illustrate this point.
  • Participants discuss the definition of invariant subspaces, noting that it refers to subspaces that remain within themselves when acted upon by \( A \).
  • Some participants express concern over their understanding of basic concepts, indicating a desire for clearer definitions and explanations.
  • There is a suggestion that the terminology used in definitions could be more intuitive for beginners.
Participants do not reach a consensus on the implications of the definitions discussed. There are competing interpretations of what it means for \( \text{Ran}(A - \lambda I) \) to be an invariant subspace of \( A \), and some participants express uncertainty about their understanding of the concepts involved.
Some participants acknowledge gaps in their understanding of the definitions and properties of invariant subspaces, leading to confusion in the discussion. The conversation reflects a range of interpretations and assumptions about the mathematical concepts at play.
This discussion may be useful for students and educators in linear algebra, particularly those grappling with the concepts of invariant subspaces and the properties of linear operators.
krcmd1
I'm trying to teach myself math for physics (a middle aged physicist wannabee). Wikipedia's proof for the exisitence of a JC form for matrix A in Cn,n states:
"The range of A − λ I, denoted by , is an invariant subspace of A"
I'm having trouble seeing why any element of Ran(A − λ I) is in the range also of A.
Also, where can I find instructions on putting equations in this forum?
Thankyou!
Ken C.
range (A-tI) is A-invariant if applying A to any vector in range A-tI, yields another such vector.
but if we have a vector w = (A-tI)v, then Aw = AAv - tAv = (A-tI)(Av).
thus whenever w is in range A-tI, then Aw is also.
the point is that all polynomials in A commute, and both A and A-tI are such polynomials.
Thank you, but it's not the invariant part that I don't get. How should I know that any w = (A-tI)v is also = Ay
I think I am confusing myself. Please forgive.
Maybe I am misunderstanding the statement "is a subspace of A." Does "Ran (A-tI) is a subspace of A" imply that any y = (A-tI)x is a linear combination of the columns of A?
krcmd1 said:
The range of A − λ I, denoted by Ran(A − λ I), is an invariant subspace of A"
Hi krcmd1! :smile:
Because any element of Ran(A − λ I) is of the form (A − λ I)V, for some vector V.
So A((A − λ I)V) = AAV - λAV = (A − λ I)AV, which is in the range of A. :smile:
For the definition of "invariant subspace", see http://en.wikipedia.org/wiki/Invariant_subspace
There's an introduction somewhere … but I can't find it … :redface:
If you look harder than I have, you'll find it! :smile:
And bookmark http://www.physics.udel.edu/~dubois/lshort2e/node61.html#SECTION008100000000000000000
and maybe
http://www.physics.udel.edu/~dubois/lshort2e/node54.html#SECTION00830000000000000000
does this show that (A-λI)V must be in the range of A? I can see that you've demonstrated that if ran(A-λI) is a subspace it is invariant, but I still don't see that every (A-λI)x = Ay for all x.
And it seems to me that this isn't even true, so maybe I just don't understand what is meant by Ran(A-λI) is a subspace of A.
oops :redface: … I left out - λ I … so it should read:
So A((A − λ I)V) = AAV - λAV = (A − λ I)AV, which is in the range of A - λ I.
krcmd1 said:
does this show that (A-λI)V must be in the range of A?.
Sorry … my mistake has misled you … :redface:
(A-λI)V isn't in the range of A …
A of (A-λI)V is in the range of A-λI.
In other words, A sends A-λI of anything into A-λI of something else. :smile:
Thanks. I really appreciate your patience.
Is there a type in the wiki article?
"A proof
We give a proof by induction. The 1 × 1 case is trivial. Let A be an n × n matrix. Take any eigenvalue λ of A. The range of A − λ I, denoted by Ran(A − λ I), is an invariant subspace of A."
Doesn't this imply that for every x, there is a y s.t. (A-λI )x = Ay?
No, it implies that for every x, there is a y s.t. A(A-λI)x = (A-λI)y.
(If x is V, then y is AV)
btw, mathwonk said the same thing, only he got it right first time! :redface:
Have another look at the wiki article on invariant subspaces. :smile:
thank you all!
It bothers me that I'm missing basic stuff. Why does Wiki say:
"... is an invariant subspace of A." instead of simply "...is an invariant subspace." (i.e. of Cn,n)?
i have completely and correctly proved the assertion made in your post.
but your assertion, that range(A-tI) is in the range of A, is different, and is also false.
(take A = 0.)
in spite of your claim otherwise, you seem not to know what the phrase "is an invariant subspace of A" means.
Please let me know when I am starting to impose.
I fully accept what you are saying, and I'm trying to correct my misconception of invariant subspace. I have been assuming that a subspace is a subset of vectors with certain closure properties. So is it correct that a subspace of A does not necessarily belong to the image of A? Is it closure under the multiplication by A that makes ran (A-lambdaI) a subspace "of A" ?
maybe I read you all wrong, but let me try too formulate:
more clearly, I think you read it wrong. Let A go from C^n to C^n
the forst thing it says is:
The range of A − λ I, is a subspace of C^n.
Lets proof this:
let [tex]w,v \in Ran(A-\lambda I)[/tex] then there exist [tex]x,y \in C^n[/tex] such that
[tex](A-\lambda I)x = w[/tex]
[tex](A-\lambda I)y = v[/tex]
so let a,b be complex numbers, then [tex]av+bw = a (A-\lambda I)y+ b (A-\lambda I)x = (A-\lambda I)(ay+bx)[/tex]
because C^n is a vector space ay+bx is also in C^n, that is (A-\lambda I)(ay+bx) is in Ran(A-\lambda I), so so by equality above av+bw is in ran(A-\lambda I), so ran(A-\lambda I) is closed under scalar multiplication and vector addition, and is thus a subspace.
the next thing it says is that the subspace W=ran(A-\lambda I) is an invariant of A, maybe more clearly, the subspace W is invariant under A, which means that
[tex]A(W) \subset W[/tex]
so when you take some element of W and use A on it then it is again in W. Let's se this:
Let v be in W, then again there is x in C^n such that (A-\lambda I)x = v, and then you get
[tex]Av = A(A-\lambda I)x = AAx-\lambda IAx = A(Ax)-\lambda I (Ax) = (A-\lambda I) (Ax)[/tex]
claerly Ax is in C^n let's call Ax = w, then you have
[tex]Av = (A-\lambda I) w[/tex]
that is the element v from ran(A-\lambda I) is again in the range of (A-\lambda I), and we have shown that the subspace ran(A-\lambda I), is invariant under A.
I know I said a lot of what is already have been said, just trying to say it different, hope it helps.
krcmd1 said:
Why does Wiki say:
Hi krcmd1! :smile:
Because there's no such thing as "an invariant subspace, period".
It has to be "an invariant subspace of a function or operation" (in this case, the matrix A).
It is a subspace of C(n,n), and it is invariant under A. :smile:
Thank you, very much.
This I understood, as you explained it before. I was trying to prove an implication that evidently the statement doesn't even have, specifically that A defines a space, i.e. the vectors formed by linear combinations of its columns, and that similarly so does (A-lambdaI), and that the second space is a subspace of the first space that is invariant.
Now that you've helped me sort that I out I fear I am in for similar misconceptions on every page as I read on.
Never fear … come back here! :smile:
have you finally understood that "invariant subspace of A" means "subspace which is invariant under action by A",
i.e. a subspace S such that for all vectors v in S, Av is also in S?
notice this definition is explicitly given in the first sentence of the link in post 6 to wikipedia, as no doubt it also is in your book. in understanding math it is crucial to read and digest the definitions of the terms.
well, I think a term like "this subspace is A-invariant" is more helpful in the beginning. Because, it does not relate to any subspace. Just tells that A does not send these elements to the outside of the subspace where you initially took them. Hence the term "invariant"
Maybe it is your cup of tea.
good point. things we take for granted are often the stumbling block for beginners. like when my third grade teacher tried to teach me about "bringing down the remainder" in long division.
she thought that "down the page" which was lying flat on my desktop, meant inwards toward my stomach, while i thought "downwards" meant toward the floor, so i thought she wanted me to put the remainders on the floor.
