Coefficient of restitution help
The discussion revolves around a problem involving the coefficient of restitution in the context of a particle attached to an elastic string. The particle is released from a height, strikes a table, and rebounds to a certain height. Participants are exploring the relationships between energy conservation, elastic potential energy, and gravitational potential energy in this scenario.
  • Participants discuss the application of energy conservation principles at different points in the motion, questioning the setup of energy equations. There is an exploration of the relationship between potential and kinetic energy before and after the bounce, as well as the implications of the coefficient of restitution.
Some participants have provided guidance on how to set up the energy equations correctly, indicating that the energy before and after the bounce should be treated separately. There is an ongoing exploration of the calculations and the effects of rounding errors on the final answer.
Participants mention potential discrepancies in the value of gravitational acceleration used in calculations, which may affect the results. There is also uncertainty regarding the roles of elastic and kinetic energy immediately after impact.
rock.freak667
[SOLVED] Coefficient of restitution help
A light elastic string AB, of natural length 0.5m and modulus of elasticity 12N, has a particle of mass 0.3 kg attached to B. The end A is attached to a fixed point at a distance of 0.7m above a horizontal table. The coefficient of restitution between the particle and the table is e. The particle is released from rest at A, hits the table and rebounds to a height of 0.22m above the table. Find the value of e,
assuming that there is no air resistance.
[itex]e= \frac{\Delta v}{\Delta u}[/itex]
KE +PE= constant
So using the law of conservation of mechanical energy:
When the mass is moving down the total energy is
[tex]E=\frac{1}{2} \frac{\lambda}{a} x^2 +mgh+ \frac{1}{2}m(u-0)^2[/tex]
[tex]E=\frac{1}{2}\frac{12}{0.5}(0.2)^2 +(0.3)(9.81)(0.7)+ \frac{1}{2}(0.3)u^2[/tex]
When the mass hits the table and comes back up
[tex]E=\frac{1}{2}\frac{12}{0.5}(0.2)^2 + (0.3)(9.81)(0.22) + \frac{1}{2}(0.3)(eu)^2[/tex]
and those two are equal and they should give me e, but I have an unknown,u, as well. What did I forget to do?
Hi rock.freak667,
Can you describe where your two energy equations are being applied at? For example, in your first equation, the first term has a length of 0.2 which would indicate that the equation is being written for when the mass is at the table, but the height is 0.7 which indicates the mass is at its starting point.
If you do write the energy equation for the beginning and ending points, then you can find the total energy on each side of the bounce, since you know the velocity there. If you write the energy equation just before and just after the bounce, you can also find the velocity right before and after the bounce.
Remember that the energy is conserved along the falling motion, and it is separately conserved along the rising motion, but the energy before the bounce and after the bounce are not the same.
alphysicist said:
Hi rock.freak667,
So then for the first equation.
[itex]mgh=\frac{1}{2}kx^2 +\frac{1}{2} mv^2[/itex]
That looks right to me; the second equation will have the same form. What does that gives?
But after impact. It still has the elastic pe which goes into gpe and ke
so that
[itex]\frac{1}{2}kx^2=mgh+\frac{1}{2}mv^2[/itex]
and v=eu.
I did that and after solving I got e=0.5 but the answer is [itex]\frac{1}{3}[/itex]
No, I think you'll have two equations of exactly the same form. For the case after the bounce, the initial energy (right after the bounce) is elastic potential energy and kinetic energy, and the final energy (at the highest point after the bounce) is gravitational potential. So the equation is the same for the other side:
[tex] \frac{1}{2}kx^2 + \frac{1}{2}mv^2 = mgh[/tex]
just with different numbers for v and h.
Well that makes some more sense..thanks, I'll try it in a while.
ok well with your equation I get 0.33 to 2dp...but the answer has 1/3 exact. Would my answer be the same since I took g=9.81 and round off errors?EDIT: wait...I was told g=10...well I got the answer thankssss
But I still am a bit unsure of the elastic and kinetic energy after impact. at impact, it has elastic, I get that. But how does it it have kinetic as well?
The coefficient of restitution relates the speeds just before and just after contact with the table (just before the collision and just after the collision). So the v in the second energy equation is after the force from the table has caused the ball to turn around and head back upwards.
oh thanks then!
