What Happens to Induced EMF in Superconductors When Magnetic Flux Changes?
  • Context: Graduate
  • Thread starter Thread starter Redbelly98
    Emf Superconductors
When magnetic flux changes in a superconducting ring, the induced electromotive force (emf) is determined by the interplay between the external alternating current (ac) magnetic field and the internal magnetic field generated by the induced current. According to Lenz's law, the induced magnetic field opposes the external magnetic field, leading to cancellation of the electric fields. In a perfect superconductor, this results in zero net emf due to the absence of resistance. However, in rings with small resistance, a small emf exists, while high resistance rings exhibit a nearly constant induced emf, governed by Ohm's law.
  • Understanding of Lenz's law in electromagnetism
  • Familiarity with alternating current (ac) magnetic fields
  • Knowledge of Ohm's law and its application in circuits
  • Basic concepts of superconductivity and its properties
  • Study the principles of superconductivity and its implications on electrical resistance
  • Learn about Lenz's law and its applications in electromagnetic induction
  • Explore the behavior of ac circuits in relation to magnetic fields
  • Investigate the effects of resistance on induced emf in superconducting materials
Physicists, electrical engineers, and students studying electromagnetism, particularly those interested in the behavior of superconductors and electromagnetic induction.
Redbelly98
Staff Emeritus
Insights Author
After following the thread "ideal conductor vs superconductor" a while, I am wondering about something that must have a simple answer.
If you change the magnetic flux through a superconducting ring, what happens to induced emf?
The net emf is the difference of the emf associated with the external ac magnetic field, and that of the internal ac magnetic field. Whenever induction takes place, the external magnetic field (time-changing or "ac" will be understood) is not the only magnetic field, herein referred as "H". The induced current in the superconductiong ring has a magnetic field as well. By Lenz' law, the induced mmf, emf, H, and E (electric field) are directed in opposite orientation to the external quantities. Thus an external H also includes an external E as well. In the ac domain, E and H are mutually inclusive, i.e. one cannot exist without the other.
When a superconducting ring is placed in the ac H/E field (they always co-exist), a current is induced. This current must have an ac H field associated with it. But the ac H field must co-exist with an ac E field. The H due to the induced current opposes the external H. Likewise for the two E fields. Cancellation occurs so that Ohms law is always upheld. SInce a current in a zero ohm resistance mandates zero voltage, the E fields must cancel. The emf, or V, is the line integral around the closed path of the net E field. Since the E field consists of equal and opposite values (extrenal plus self induced), the net value is zero.
When the conducting ring has a small resistance, the E fields do not perfectly cancel, so that a small emf exists. Ohms law is upheld. For low resistance rings, the induced current is approx. constant, and the induced emf varies with the resistance. Thus I is approx. fixed, and V varies with R per Ohms law, i.e. V = I*R.
For a high resistance ring, the induced current is small, as well as the associated E/H fields. Thus the net E/H values are approx. those of the external E/H fields. Then, the induced emf is approx. constant, and the induced current is I = V/R.
Does that clear things up? If you still have trouble, rest assured that brilliant people struggle with this. It isn't trivial. BR.
Claude
Yes, thank you. If I understand you, the induced current generates a flux that will cancel the flux change due to the external field change. Zero flux change --> zero emf.
Thanks,
Mark
  • · Replies 27 ·
  • · Replies 42 ·
  • · Replies 194 ·
24K
