Running 3 Miles: The Staggering Implications
  • Context: High School
  • Thread starter Thread starter Namloh2000
    Frames
The discussion revolves around the concept of motion and Zeno's Paradox, specifically in the context of running a distance of 3 miles. Participants explore the implications of dividing distances into infinite halves and the resulting paradoxes related to motion and time.
  • Exploratory, Debate/contested, Conceptual clarification
  • One participant questions how it is possible to run 3 miles if one must exist at all halfway points, suggesting that this leads to the conclusion of running forever.
  • Another participant identifies the issue as Zeno's Paradox, noting that the sum of an infinite series can still be finite.
  • A different participant attempts to clarify the paradox by referencing the finite sum of the series ½ + ¼ + 1/8 + ..., indicating that the total time taken is finite because each step takes half as much time as the previous one.
  • One participant expresses skepticism about the mathematical explanations provided and suggests further exploration in a different forum section.
Participants do not reach a consensus on the understanding of Zeno's Paradox and its implications for motion. There are differing levels of confidence in the mathematical explanations provided.
Some assumptions about the nature of motion and the interpretation of infinite series are not fully explored, leading to unresolved questions about the relationship between distance, time, and the concept of infinity.
Namloh2000
Moving in Frames??
okay, so let's say I ran 3 miles. At one point, I must have been halfway between start and finish right? From the halfway point, I must have existed halfway from there and the remaining 1.5 miles also. And halfway between THAT point and the finish. Then halfway from THAT point and the finish. I must have existed at all these halfway points, but if motion was fluid, couldn't this not be accomplished, being that I can divide my new remaining distance in half from here to infinity, meaning that I would have to be running forever? The implications are staggering!
seriously though, what's up - how come I can run 3 miles?
This is known as Zeno's Paradox. The sum of an infinite series is still finite. Google it. Much has been said about it.
okay so i read up a bit and the solution seems to be something in that because the sum of the series ½ + ¼ + 1/8 + ... is equal to 1. The total time is finite because each step is done in half as much time as the previous step.
But I still don't understand.
OK, I see that you don't have much faith in mathematics. Anyway, go visit here if you are interested: https://www.physicsforums.com/showthread.php?t=22419
You can open a new thread in the General Math section if you still don't believe in Zeno's Paradox. You will get more replies there, and most of them will be harsh. So good luck! :)
  • · Replies 25 ·
  • · Replies 27 ·
  • · Replies 33 ·
  • · Replies 35 ·
