Why Can Hydrophobic Molecules Pass Through the Amphipathic Plasma Membrane?
The discussion centers on the mechanisms by which hydrophobic molecules can pass through the amphipathic plasma membrane, particularly focusing on diffusion and the selective permeability of the membrane to different types of molecules, such as steroid hormones versus peptide hormones.
  • One participant questions why the amphipathic nature of the plasma membrane allows only hydrophobic substances to pass through.
  • Another participant explains that various mechanisms, including simple diffusion for small uncharged molecules and transport proteins for ions and larger molecules, facilitate material crossing the membrane.
  • A participant highlights the difference in permeability between steroid hormones, which can diffuse through the membrane, and peptide hormones, which cannot, raising questions about selective permeability.
  • It is noted that water, a hydrophilic molecule, can diffuse through the membrane, suggesting that not all hydrophilic substances are excluded.
  • A later reply discusses the energetics involved in diffusion, explaining that polar molecules face unfavorable energetics when attempting to cross the membrane due to their interactions with solvent and membrane components, while lipid molecules experience weaker interactions, making their passage less energetically costly.
Participants express differing views on the mechanisms of diffusion and the reasons behind the selective permeability of the plasma membrane, indicating that multiple competing explanations remain without a clear consensus.
The discussion involves assumptions about the energetics of molecular interactions and the conditions under which different types of molecules can cross the membrane, which are not fully resolved.
biophysics
if the Plasma membrane is amphipathic (hydrophobic and hydrophilic), why does it only allow hydrophobic stuff to pass thru?
There are several mechanisms allowing material to cross the cell membrane. Simple diffusion is thought sufficient for small uncharged molecules- CO2, urea, ammonia; channels and trasporter proteins are used for ions and larger molecules like glucose. There is a water channel as well (aquaporin).
Even larger things are transported in via endocytosis.
Thanks for the reply,
My question is about diffusion across membrane. Steroid hormones are able to diffuse while peptide hormone can't. If the membrane is amphipathic (hydrophobic and hydrophilic), why does it selectively allow hydrophobic stuff to pass thru? and not hydrophilic. Thanks
Well water can diffuse through a membrane and it's pretty hydrophillic.
What you're really looking for though is unfavorable energetics. Polar molecules are far less favored to diffuse through a membrane than a lipid molecule.
And that stems from the fact that they are in solution. Polar and charged ions will be favored to stay in their current solvent or stick to the surface of the bi-layer since, in order to pass through, they would need energy to shed their solvent and their interactions with the charged phosphates on the surface so they could pass through.
Lipid molecules interact much more weakly even with like-minded molecules ... just through van der waal's. Therefore, they're not covered in a solvent shell, and it's not that much more unfavorable for them to pass through the charged phosphate layer than it was for them to pass through the water they were just in on the other side especially if it's down their concentration gradient. The van der waals forces that would "stick" them into the middle of the bilayer are also weak, so if there is a concentration gradient providing energy for diffusion all the way through, they'll diffuse.
9K
9K
  • · Replies 18 ·
