What Is the Maximum Angular Momentum of a Particle Moving Past a Point?
The maximum angular momentum of a particle moving past a point O occurs when the particle's distance from the point is perpendicular to its velocity. Given a mass of 2 kg and a velocity of 3 m/s, with a minimum distance of 2 m from point O, the angular momentum can be calculated using the formula L = m * v * r, where L is angular momentum, m is mass, v is velocity, and r is the perpendicular distance. Thus, the maximum angular momentum is L = 2 kg * 3 m/s * 2 m = 12 kg·m²/s.
  • Understanding of angular momentum concepts
  • Familiarity with the formula L = m * v * r
  • Basic knowledge of linear motion
  • Ability to interpret physics problems involving geometry
  • Review the derivation of angular momentum formulas in classical mechanics
  • Explore examples of angular momentum in different physical scenarios
  • Study the relationship between linear and angular momentum
  • Investigate the effects of varying mass and velocity on angular momentum
Students studying physics, particularly those focusing on mechanics, as well as educators looking for clear examples of angular momentum calculations.
dinonichas
A particle moves in a straight line past a point O, as shown below. At which point is the angular momentum maximum (with respect to O)? If the minimum distance between O and the line is 2 m, and the object has a mass of 2 kg and a velocity of 3 m/s, what is the maximum angular momentum of the particle with respect to O?
angular momentum is equal to:
Iω= (mr^2)mv ??
0,i think,because the momentum should be 90 degree from the radius to make the angular momentum.so in this case the particle is moving in the straight line with the point O so it will be 0
Iω= (mr^2)mv ??
[tex]\omega \neq mv[/tex]
There is a simple formula relating angular momentum to mass, velocity, and radius vector. Find that formula in your textbook and use it.
This is correct.
But this isn't. If the point O is 2 m from the line, the angular momentum (with respect to that point) can't be zero.
  • · Replies 17 ·
  • · Replies 45 ·
18K
