Solving Spring and Block: Find Block Speed
  • Thread starter Thread starter grouchy
    Block Spring
The problem involves a 6 kg block propelled by a compressed spring that is released, traveling 1.2 m on a rough surface with a coefficient of kinetic friction of 0.4. The speed of the block as it leaves the spring is calculated using the formula v = √(2kNd/m), resulting in a speed of 3.07 m/s. The kinetic energy of the block is converted into work done against friction as it moves along the surface. The discussion clarifies that the distance of 1.2 m does not include the initial 6 cm compression of the spring.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of kinetic energy and work
  • Knowledge of friction and its coefficients
  • Basic algebra for manipulating equations
  • Study the principles of conservation of energy in mechanical systems
  • Learn about the dynamics of friction and its impact on motion
  • Explore the calculations involved in spring potential energy
  • Investigate real-world applications of springs in mechanical engineering
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of motion involving springs and friction.
grouchy
[SOLVED] Spring and Block
A spring is compressed 6 cm and an 6 kg block is placed against it. when the spring is released the block shoots forward along a rough, horizontal surface traveling 1.2 m before coming to a stop. The coefficient of kinetic friction between the block and the surface is 0.4. Find the speed acquired by the block as it leaves the spring.
I try to use conservation of energy but I'm having trouble since I'm not given k or v (find k would be the second question).
Although the problem does not make it clear, let's assume that the 1.2 m does not include the 6 cm that the spring expands. Further, assume that the rough surface only begins after the spring has expanded.
The block leaves the spring with some speed. What happens to its KE? How much work is done by friction?
GOT it, I kept assuming that I need to use the potential of the spring. All i need was..
1/2mv^2 = k(coefficient of kinetic friction)Nd
v = square root of (2kNd/m) = 3.07 m/s matches up perfect
Also, I used the 1.2 m for d.
thx.
  • · Replies 27 ·
11K
  • · Replies 33 ·
  • · Replies 16 ·
