Thread Closed
Heat Exchanger Thermal Calculations
Share Thread Thread Tools
May13-08, 09:04 AM   #1
Hello,
Can anyone get me Heat exchanger thermal formula and equations
Tom
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
May13-08, 09:47 AM   #2
Recognitions:
Gold Membership Gold Member
There's a lot more to understanding heat exchangers than a few formulas...
May24-08, 07:38 AM   #3
what type of the two fluids used in this heat exchanger?
the most imp formula which is used with the exchangers its doing the heat balance for these two fluids,lets say its a condenser,
so the two fluids are the steam and the water,
the formula used:
heat added to the water(Qadded)=the heat rejected by the steam(Qrej)
mdot(cw)*Cpw*(Tout-Tin)=Mdot(st)*hst
where:Mdot is:mass flow rate,Cp is:specific heat of water at constant pressure,T is:temperature&h is:the enthalpy of a saturated steam.
generally,its doing a heat balance for the two fluids using in the heat exchanger by the same way with the condenser.
let me know if i missed something with what i've mentioned,
thanks for the forum.
Thread Closed
Thread Tools
Similar Threads for: Heat Exchanger Thermal Calculations
Thread Forum Replies
Car radiator as a heat exchanger Engineering Systems & Design 13
Heat Exchanger Capacity Mechanical Engineering 25
heat exchanger Materials & Chemical Engineering 0
Is this even possible? (heat exchanger problem) Mechanical Engineering 4
Heat exchanger question. Engineering, Comp Sci, & Technology Homework 0
