Quick question about equilibrium of a reaction
The discussion revolves around the equilibrium of a chemical reaction involving cobalt chloride and water, specifically addressing the effects of adding more water to the system. Participants explore concepts related to chemical equilibrium, particularly in the context of Le Chatelier's principle.
  • Homework-related
  • One participant suggests that adding more water would not change the equilibrium because the concentration of water cannot be altered.
  • Another participant questions the effects of disturbing the equilibrium and relates it to Le Chatelier's principle.
  • Some participants argue that water does have a concentration and inquire about the equilibrium's response to the addition of more water.
  • There is a suggestion that the reaction may be conducted in alcohol, which could allow for control over water concentration.
  • A later reply indicates that the cobalt species was likely prepared in alcohol to prevent reversion to the water product.
  • One participant provides a revised version of the reaction equation, indicating a clearer representation of the chemical species involved.
Participants express differing views on whether adding more water affects the equilibrium, with some asserting it does not and others suggesting it may. The discussion remains unresolved regarding the impact of water addition on the equilibrium state.
There are uncertainties regarding the control of water concentration in the reaction and the implications of using alcohol as a solvent. The discussion also highlights the need for clarity in the chemical equations presented.
mjolnir80
we have a solution of
Cocl[tex]^{}2-_{}4[/tex](alcohol) + 6H[tex]_{}2[/tex]O(l) <---> Co(H[tex]_{}2+[/tex]O)[tex]_{}6^{}2+[/tex](aq) + 4Cl-(aq)
at equilibrium
what would happen if we were to add more H2O?
we can't really change the concentration of the water so nothing would happen?
edit: sorry abot the bad reaction formula
this is an equilibrium, what happens when one side of the equilibrium is disturbed? what chemical principle is this related to?
its related to le chatelires principle but I am not sure whether the water has any effect at all because we can't really change the concentration of the water
any reactant or solvent in a chemical reaction has a concentration, even water. So what will the equilibrium do if more water is added?
It is hard to tell from your reaction, but isn't it done in alcohol, in which case water concentration can be easily controlled?
likely the CoCl2 4- was prepared with an alcohol content in its solution to maintain this species and not revert to the water product.
at equilibrium
water is a reactant here.
CoCl2-4(alcohol) + 6H2O(l) <---> Co(H2O)6+2(aq) + 4Cl-(aq)
at equilibrium
Here is a cleaned up version of your equation. Hit 'quote' to see how I did it.
I think it should be:
CoCl4-2(alcoholic) + 6H2O(l) <---> Co(H2O)6+2(aq) + 4Cl-(alcoholic)
25K
