Finding inverse of a matrix and solving given equations.
  • Thread starter Thread starter cmcc3119
    Inverse Matrix
The discussion revolves around finding the inverse of a matrix and solving corresponding systems of equations. The original poster expresses confusion regarding the process of deriving solutions from the matrix inverse and the equations provided.
  • Participants discuss the relationship between the matrix and the system of equations, noting the need to multiply by the inverse to isolate the variable vector. Questions arise about the principles guiding this approach and the reasoning behind using the inverse.
Some participants have offered insights into the mathematical principles involved, such as the relationship between a matrix and its inverse. There is an ongoing exploration of how to manipulate the equations back into the standard form and the implications of using the inverse.
The original poster is preparing for a quiz and is working with sample problems, which may impose constraints on the depth of understanding expected. The discussion reflects a mix of foundational concepts and specific problem-solving techniques.
cmcc3119
[SOLVED] Finding inverse of a matrix and solving given equations.
Hi,
I have a quiz tomorrow and I am looking at the sample quiz right now but I don't understand how the answers work!
Here is the question:
Find the inverse of the matrix A=
-1 3 3
-2 1 2
0 1 1
Hence solve the following systems of equations:
-x1 + 3x2 + 3x3 = 5
-2x1 + x2 + 2x3 = 2
x2 + x3 = 1
and
-x + 3z = -5
2x - y - 4z = 2
-2x + y + 5z = -1The answer says the inverse of A
-1 0 3
2 -1 -4
-2 1 5
Then it spells out how to solve the equations but the is the part that confuses me:
"The first system of equations corresponds to the matrix equation A
[x1 = [5
x2 = 2
x3 ] = 1]
Therefore, as A is invertible (i.e. A-1 exists),
[x1
x2
x3]
=A inverse of
[5
1]
which =
[-1 0 3 [5 [-2
2 -1 -4 2 = 4
-2 1 5 ] 1] -3 ]
So x1 = -2, x2 = 4, x3 = -3.
Can someone please explain how they just did that because I really can't understand where they derive -2, 4 , 3 from and what they do with [5, 2 ,1]
So you've got this matrix [tex]\left(\begin{array}{ccc} -1 & 3 & 3 \\<br /> -2&1&2 \\<br /> 0&1&1 <br /> \end{array}\right)[/tex] and you set of equations.
The first thing to note is that your equations are equal to [tex]\left(\begin{array}{ccc} -1 & 3 & 3 \\-2&1&2 \\ 0&1&1 \end{array}\right) \left(\begin{array}{c}x_1 \\ x_2 \\ x_3 \end{array}\right)=\left(\begin{array}{c}5\\2\\1\end{array}\right)[/tex].
So, in order to find (x1,x2,x3)T you need to multiply the equation on the left by the inverse of A. This will give (x1,x2,x3)T= something.. where you can calculate the "something" by matrix algebra.
So how would I know that I have to multiply the left by the inverse of A to find the answer? Is there some basic principle or law that I am unaware of?
Well, yes. The easiest way to solve the equation Ax=b (for a matrix A and vectors x and b) is to try and get x on it's own, no? Now, you know that [itex]AA^{-1}=A^{-1}A=I[/itex], so you know that multiplying the equation by A inverse will leave you with [itex]x=A^{-1}b[/itex], from which you can read off values for x.
Its so hard to put all these number and boxes back into simple ax = b and again rearrange. Thanks cristo for your help!
No worries
  • · Replies 24 ·
