Does Light have an Magnetic Field in a Vacuum?
The discussion centers around whether light possesses a magnetic field in a vacuum and how it interacts with external magnetic fields, particularly in the context of a laser beam and a rare Earth magnet. Participants explore theoretical implications, experimental observations, and historical effects related to light and magnetism.
  • Some participants note that light, as electromagnetic radiation, has electric and magnetic fields but question the observable effects of a strong magnet on a laser beam.
  • There is a suggestion that the magnetic field of the magnet should interact with the magnetic field of the light, potentially causing deflection.
  • One participant argues that any deflection would be negligible and asks for conditions that might make it detectable.
  • A participant references Maxwell's equations, stating that they imply no interaction between the magnetic fields of the magnet and the light, but acknowledges that there are effects in a vacuum due to quantum electrodynamics (QED).
  • Another participant discusses the Inverse Faraday Effect and its implications for the electromagnetic nature of light, suggesting that light can interact with materials in ways that change its properties.
  • The historical context of the Faraday effect is mentioned, highlighting that magnetic fields can rotate the plane of polarized light.
  • Participants discuss the Zeeman effect, noting that it is an indirect effect where the magnetic field influences atoms rather than light directly.
Participants express differing views on the interaction between light and magnetic fields, with some arguing for observable effects and others suggesting that these effects are negligible or indirect. The discussion remains unresolved regarding the extent and nature of these interactions.
Participants reference various effects and theories, including the Inverse Faraday Effect and vacuum birefringence, but the discussion does not reach a consensus on the mechanisms or implications of these phenomena.
Buckeye
Light, aka electromagnetic radiation, is said to have electric and magnetic fields as it propagates thru space. When I hold a 1 Tesla rare Earth magnet next to a beam of red laser light, nothing happens. Why?
What do you expect to happen?
I kinda expected the light to deflect to some extent.
Why?
Doc Al said:
Why?
It seems that the magnetic field of the magnet should interact with the magnetic field of the light thus causing some change.
Yes, but it would be negligible you couldn't notice it with your eyes.
Can you suggest what conditions might be needed to make the deflection detectable by some form of instrumentation?
Maxwell's equations are linear and there is therefore no interaction between magnetic fields. The magnetic field of the dipole magnet satisfies the Maxwell equations. The electromagnetic waves from your laser is another solution. Add them up and the sum of the two solutions is another solution.
So, this suggests that there shouldn't be a deflection. This is not 100% true. The most important effect that does lead to a deflection is the fact that the magnet induces changes in the air that the laser light moves through. Even though the full problem is linear, if you pretend that the medium isn't there, then it is effectivel nonlinear.
But even in a perfect vacuum there are QED effects due to virtual electron positron pairs. The magnet effectively changes the QED vacuum and then the laserlight that moves through it will be deflected. When light enters a region with a magnetic field, then it behaves as if there is an index of fraction. This effect is largest if the light enters the region orthogonal to the magnetic field. The two polarizations states of the light with the magnetic component parallel or orthogonal to the external field have different indices of refraction. That causes the so-called vacuum birefringence effect.
http://arxiv.org/abs/hep-ph/9806417"
Hi Count!
Hmmm.
If memory serves me right, achiral (non-polarized) laser light - when shone on various materials produces an Inverse Faraday Effect that can be interpreted various ways, but it still represents a significant change in the EM nature of the light that emerges and hits the phase sensitive optical detector. Myron Evans and Jean-Pierre Vigier are both busy developing a new quantum theory that is mixed into Evans's "Generally Covariant Unified Field Theory" as a result of discovering this phenomenon a few years ago.
The much older, Optical Faraday Effect produces a similar phenomenon when various wavelengths of noncoherent light are passed thru achiral materials that are envelop by a horseshoe type permanent magnet.
Both effects seem to involve magnetic field changes almost exclusive of the electric field of light.
We can debate the change as being a change of spin or orbital angular momentum when the transverse EM fields of light interact with solid matter, but we are still ignoring the longitudinal nature of the magnetic field in light which is almost never addressed and is considered too weak to be relevant.
Keeping the above in mind, if light should not interact with a rare Earth magnet, then why do both incoherent and coherent forms of light interact with the magnetic nature of materials in either the presence or the absence of a permanent magnet?
On top of that we can add - the spin polarized nature of electrons that result from laser light being shone on GaAs and many other achiral materials. How did non-polarize light produce spin polarized electrons?
Any insight will be greatly appreciated. Thanks!
Michael Faraday showed in 1845 that a magnetic field rotated the plane of polarized light
(the Faraday affect mentioned above).
Michael was not a member of PF, so his result was not posted to this thread.
Magnetic fields do indeed affect light. It is called the Zeeman effect. It is a very small effect.
Isn't the Zeeman effect indirect in its effect on light? That is, its magnetic field must first affect an atom to alter the resultant spectra. This seems to deny such an action in vacuo.
Yes, after reading a little more I see Zeeman effect is indirect - it only affects the emitting atom; not the light itself.
  • · Replies 65 ·
  • · Replies 41 ·
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 27 ·
