| Thread Closed |
Double differentials and some curious problems |
Share Thread | Thread Tools |
| May15-08, 03:30 PM | #1 |
Hello, I'm toying around with a Jacobian that has raised some interesting problems. It's a case of differentiating rates of some variable x, with respect to itself.
First one I suspect the answer is zero, though perhaps my reasoning is a bit flawed. 1. [tex] \frac{d}{d\theta}(\dot{\theta}) =\frac{d \dot{\theta}}{dt} \times \frac{dt}{d\theta} =\ddot{\theta} \times \dot{\theta}^{-1} =\ddot{\theta} / \dot{\theta} =\frac{\Delta p }{\Delta t}}/\Delta p =\Delta t \approx 0 [/tex] The second I think you apply the total derivative rule to, but maybe not, should the angle and angle-rate be considered as two separate variables? 2. [tex] \frac{d}{d\theta}(\dot{\theta}cos\theta) =\frac{dF}{d\theta} =\frac{\partial F}{\partial \dot{\theta}} \times \frac{d\theta}{dt} + \frac{\partial F}{\partial \theta} \times \ddot{\theta} =\dot{\theta}cos\theta - \ddot{\theta}\dot{\theta}sin\theta [/tex] Last one has me flummaxed... 3. [tex] \frac{d}{d\theta}(\theta+\dot{\theta}dt)=? [/tex] And finally 4. [tex] \frac{d}{d\dot{\theta}}(q sin\phi tan\theta + r cos\phi tan\theta) =\frac{1}{\ddot{\theta}}\times \frac{d}{dt}(q(t) sin\phi (t) tan\theta (t)+ r (t) cos\phi (t) tan\theta (t)) =? [/tex] Number 4 I arrive at from the chain rule (an example below): [tex] \frac{dy}{d\dot{\theta}}=\frac{dy}{dt} \times \frac{dt}{d\dot{\theta}} =\frac{dy}{dt} \times \left(\frac{d\dot{\theta}}{dt}\right)^{-1} =\frac{\dot{y}}{\ddot{\theta}} [/tex] Could anyone confirm what I've done so far (or point out any mistakes)? Cheers. |
| May16-08, 04:07 AM | #2 |
Just to clarify, 3. slightly, the [tex]dt[/tex] is actually the sample period, so [tex]\dot{\theta}dt\approx \Delta\theta[/tex], but I'm unsure how this affects the derivative...
Also, in 2. maybe I should use the product rule, but I think the term you are using for differentiating needs to be different... (product rule) [tex] \frac{d}{dz}(xy)= x\frac{dy}{dz}+y\frac{dx}{dz} [/tex] |
| May16-08, 05:02 AM | #3 |
![]() I'm confused … what are ∆p and ∆t? And what is the context that this is a part of? Is it something like a Lagrangian, where θ and θ' are treated as independent variables, so that ∂θ'/∂θ = ∂θ/∂θ' = 0 anyway? If not, I don't understand how you get from θ''/θ' to (∆p/∆t)/∆p.
| May16-08, 05:43 AM | #4 |
Sorry! I just jumped into a shorthand replace with the following:
[tex] \frac{\Delta p }{\Delta t}}/\Delta p =\frac{\Delta \dot{\theta} }{\Delta t}}/\Delta \ddot{\theta} [/tex] The context is trying to create a Jacobian matrix to estimate the covariance for angular rates. I don't really want to delve into to much detail as the matrix is rather large, but in a simplified form: [tex] \mathbf{x}_{k|k-1}=\mathbf{A}_k\mathbf{x}_{k-1|k-1} [/tex] and I need to find [tex] \mathbf{J}_k=\frac{d(\mathbf{x}_{k|k-1})}{d(\mathbf{A}_k\mathbf{x}_{k-1|k-1})} [/tex] Thinking about 3. a bit more I believe [tex]1[/tex] would be a fairly accurate approximate. |
| May16-08, 10:56 AM | #5 |
That is
[tex] \frac{\Delta p }{\Delta t}}/\Delta p =\frac{\Delta \dot{\theta} }{\Delta t}}/\Delta \dot{\theta} [/tex] |
| May16-08, 12:49 PM | #6 |
Hi Ultimâ!
![]() You seem to be trying to differentiate one element of a matrix with respect to another. ![]() And does the J in Jk mean Jacobian, or angular momentum? (btw, the LaTeX for ∂ is \partial … see http://www.physics.udel.edu/~dubois/...00000000000000) |
| May16-08, 01:39 PM | #7 |
Recognitions:
For your first one:
[tex]\frac{d}{d\theta}(\dot{\theta})=\frac{d \dot{\theta}}{dt} \times \frac{dt}{d\theta}=\ddot{\theta} \times \dot{\theta}^{-1}=\ddot{\theta} / \dot{\theta}= \frac{d}{dt}\ln \dot{\theta}[/tex] If that total derivative is equal to zero, then it means you must have [itex] \ln \dot{\theta} = \mbox{const}[/itex], which means [itex] \dot{\theta} = \mbox{const}[/itex], which means [itex]\theta(t) = a + bt[/itex], which won't be the case in general. The reason it's not zero in general is that for general cases you can in principle invert [itex]\theta(t)[/itex] to get [itex]t(\theta)[/itex], and so one could then write[itex]\ddot{\theta}(t) = \ddot{\theta}(t(\theta)) = \ddot{\theta}(\theta)[/itex]. |
| May17-08, 01:12 PM | #8 |
Recognitions:
Actually, I didn't even need to do the bit with the ln. From the very first term, if [itex]d\dot{\theta}/d\theta[/itex] is zero, then [itex] \dot{\theta} = \mbox{const}[/itex] and [itex]\theta = a + bt[/itex]. |
| May18-08, 01:57 PM | #9 |
tiny-tim - Sorry if I didn't make things very clear, but I was just hoping people could check what I had done seemed reasonable - that is simplifying the derivatives in 1.->4. These happen to be four of the elements of J (yes it is a Jacobian) that I'm inputting as a matrix for an Extended Kalman filter (EKF) I'm working with. This simplification means having things in terms of p q r [tex]\phi \ \theta \ \psi [/tex] or their rates (values of which the EKF has available for making calculations).
I think Mute is suggesting I shouldn't simplify after the fourth part of No. 1, which do-able, though I don't actually have theta_doubledot available and would need to use [tex]\frac{\dot{\theta}_t - \dot{\theta}_{(t-1)}}{dt}[/tex] to estimate this.... |
| May19-08, 04:20 AM | #10 |
This is a little bit guessing, but if you are playing around with jacobian then it is most probably
[tex]\frac{\partial \dot{\theta}}{\partial \theta} = 0[/tex] and the jacobian is evaluated at some point... Also you cannot always invert the function [itex]\theta(t)[/itex] and you don't check if [itex]\frac{dt}{d\theta}[/itex] is invertible... |
| Jun24-08, 10:50 AM | #11 |
Well since I was asked for it, here's the full problem I have (see pdf),...Anything wrong with my reasoning here for the elements I have calculated for the Jacobian?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Double differentials and some curious problems
| Differentials multiplied by differentials | Calculus & Beyond Homework | 3 | ||
| Differentials under differentials in integrals | Calculus & Beyond Homework | 3 | ||
| Proving Identities and Double angles problems | Precalculus Mathematics Homework | 1 | ||
| Can someone double check to see if I did these problems correctly? E-Flux problems | Introductory Physics Homework | 3 | ||
| Double checking charges and electrical field problems | Introductory Physics Homework | 16 | ||
