Thread Closed
Introduction to limits problem
Share Thread Thread Tools
May16-08, 06:15 AM   #1
hello,
in my calculus introduction book, it is written:
Let a rational function: [tex]f(x) = \frac{{p(x)}}{{q(x)}}[/tex] and a, a real number
If q(a) equals 0, but not p(a), then [tex]{\lim }\limits_{x \to a} f(x)[/tex] does not exist.
however, while doing exercises on the internet, i found that:
[tex]{\lim }\limits_{x \to 1} \frac{{2 - x}}{{(x - 1)^2 }} = \infty[/tex]
is my textbook wrong?
thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
May16-08, 08:12 AM   #2
Would you say that the other limit exist?
May16-08, 11:27 AM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Saying that [itex]\lim_{\stack{x\rightarrow a}}f(x)= \infty[/itex] just means that the limit does not exist in a particular way.
May16-08, 02:56 PM   #4
Let's convert what you have found on the net into the formula in your textbook. so q(x) = (x-1)^2 , p(x) = 2 - x and x--> 1. From here, we can say that q(1) = 0 and p(1) = 1. If you calculate p(1) / q(1), you get infinitity. It means that this limit does not exist.
May18-08, 08:57 PM   #5
As x goes to 1, the denominator goes to zero (since, of course, (x-1)^2 = (1-1)^2 = 0. The smaller the denominator, the larger the output of the function. Since x makes the denominator shrink, we can rephrase the limit to be: "as denominator goes to zero, the output goes to a very large number."
Lets look at a different, more simple function for a moment: f(x) = 1/x. As x becomes very small, the output ("y") becomes very very large. So what happens when x goes to exactly zero? This is hard to get out head around, so instead of saying "what happens when x is zero," we shall make an 'inverse function.' Now we will take OUTPUTS, and recieve x INPUTS. That is, large numbers will yield small numbers (where the small number, when put under a one, yields the original large number.)
y= 1/x ; now use algebra to move the terms: x = 1/y.
Now when y becomes large, x becomes small -- this is the inverse of the original function, now we START with the large number, y, and receive the small number x in return. What value of y will make x become zero? As y becomes increasingly large, x becomes increasingly small.
We can now say:
[itex]
\lim_{\stack{y\rightarrow a}}f(y)= 0
[/itex]
The question is, what value of a will make f(y) become zero? No matter HOW large we make y, x will still not be EXACTLY zero. It will become very close to zero, but it will not actually BE zero. Hence when x is actually 1 in your original example, we say that the output is "undefined." However, it is useful for practical purposes to say it is "infinity," since as x goes to 1, the output becomes increasingly large -- it's a way of saying the output becomes large without bound, even if the actual function is undefined at the value x is approaching (in this case, we get a divide by zero error.)
In this sense, as y goes to a large number, x goes to a small number. We say the limit is "zero" or "infinity" because zero and infinity signify the apex of each extreme. There is a very ambiguous nature behind limits and infinity, so beat yourself up if you can't get your head around it (I don't think many people do, if any.)
As a side note, there is a lot of inquiry as to the nature of infinity. You may be interested in reading about set theory and the extended complex plane -- they make some odd use of the notion of "infinity," though I'm unsure how to interpret it myself so I'll avoid going into detail here.
Thread Closed
Thread Tools
Similar Threads for: Introduction to limits problem
Thread Forum Replies
Limits problem Calculus & Beyond Homework 7
Introduction To Calculus Problem (Intersection) Calculus 2
Arthur Mattuck, Introduction to Analysis, Problem 5-7 Calculus & Beyond Homework 1
Introduction Physics: Free Fall problem Introductory Physics Homework 1
Solution to Griffiths introduction to EM problem 2.26 Introductory Physics Homework 4
