Proving Perpendicularity of FE & AB in a Semicircle
  • Thread starter Thread starter Saad
The problem involves proving that line FE, extended, is perpendicular to diameter AB of a semicircle, where points C and D are arbitrary points on the semicircle's arc. The proof can be simplified using analytical geometry rather than classical methods, which may involve identifying congruent triangles. Notably, triangles ACB and ADB are right triangles, with right angles located at points C and D, respectively. This geometric configuration provides a clear pathway to establish the perpendicularity of FE to AB.
  • Understanding of semicircles and their properties
  • Familiarity with analytical geometry concepts
  • Knowledge of right triangles and their characteristics
  • Ability to identify and work with intersecting lines and angles
  • Study the principles of analytical geometry and its applications in proofs
  • Explore the properties of semicircles and their diameters
  • Learn about the relationships between angles in intersecting lines
  • Investigate methods for proving triangle congruence and similarity
Students of geometry, mathematics educators, and anyone interested in mastering geometric proofs and analytical methods.
Saad
AB is the diameter of a semicircle. Points C and D are ANY two points on the arc of the semicircle. AD and BC intersect at E. AC and BD are extended to meet at F. Prove that FE extended is perpendicular to AB.
I need any help possible because i have no idea of how to solve this proof problem! pleasezzzzzzzzzzzzz
The assertion is fairly easy to prove if you rephrase it in the terms of analytical geometry.
It looks difficult to prove it by "classical" means (i.e. identifying congruent triangles and suchlike)
Use the fact that triangles ACB and ADB are right triangles with right angle at C and D.
  • · Replies 20 ·
  • · Replies 21 ·
