Expectation values and operators.
The discussion focuses on the calculation of expectation values for operators in quantum mechanics, specifically the arbitrary operator \(\tilde{p}^{n}\tilde{y}^{m}\), where \(\tilde{p}\) represents the momentum operator and \(\tilde{y}\) represents the position operator. It is established that the expectation value \(\langle \tilde{p}^{n}\tilde{y}^{m} \rangle\) is not equal to the product of the individual expectation values \(\langle \tilde{p}^{n} \rangle \langle \tilde{y}^{m} \rangle\). The correct calculation involves integrating the product of the wavefunction \(\Psi(x)\) with the operators, leading to the expression \(\int \Psi^*(x) \hat{p}^n \hat{y}^m \Psi(x) \, \mathrm{d}x\).
  • Understanding of quantum mechanics principles
  • Familiarity with operators in quantum mechanics
  • Knowledge of wavefunctions and their properties
  • Ability to perform integrals involving complex functions
  • Study the properties of quantum mechanical operators
  • Learn about the position and momentum operators in quantum mechanics
  • Explore the concept of expectation values in quantum mechanics
  • Investigate the use of wavefunctions in operator calculations
Students and professionals in quantum mechanics, physicists working with operator theory, and anyone interested in advanced calculations of expectation values in quantum systems.
wads
i'm just not sure on this little detail, and its keeping me from finishing this problem.
take the arbitrary operator [tex]\tilde{p}^{n}\tilde{y}^{m}[/tex] where p is the momentum operator , and x is the x position operator
the expectation value is then <[tex]\tilde{p}^{n}\tilde{y}^{m}[/tex] >
is this the same as <[tex]\tilde{p}^{n}[/tex]> <[tex]\tilde{y}^{m}[/tex]>?
if not, how would i go about calculating <[tex]\tilde{p}^{n}\tilde{y}^{m}[/tex] >?
In general, they are not the same. The expectation value of an operator [itex]\hat A[/itex] is
[tex]\int \Psi^*(x) \hat A(x) \Psi(x) \, \mathrm{d}x[/tex]
where [itex]\Psi(x)[/itex] is your wavefunction (assuming you are talking QM here).
In this case,
[tex]\int \Psi^*(x) \hat p^n \hat y^m \Psi(x) \, \mathrm{d}x<br /> \neq<br /> \left( \int \Psi^*(x) \hat p^n \Psi(x) \, \mathrm{d}x \right)<br /> \left( \int \Psi^*(x) \hat y^m \Psi(x) \, \mathrm{d}x \right).[/tex]
You could write out [itex]\hat p[/itex] in the position basis and work out what [itex]\hat p^n(y^m \Psi)[/itex] looks like.
