Load bearing structure made of matchsticks
The original poster is working on a project to design a load-bearing structure made of matchsticks that can support the weight of a 17" computer monitor. They are exploring how the force of gravity from the monitor's mass will be distributed across the matchstick structure, particularly focusing on the use of matchstick trusses with pin joints.
  • The original poster questions how to accurately determine the distribution of forces, given their previous experiences with simpler problems that assumed uniform weight distribution. They seek clarification on whether the weight acts through the center of mass and how to analyze the reactions at the monitor-structure interface.
Some participants have provided insights on determining support reactions and suggested using static equilibrium equations. They also discussed the importance of considering concentrated loads at the joints beneath the monitor support. The conversation reflects varying interpretations of the monitor's weight distribution and its impact on the truss design.
The original poster mentions that their monitor is not a modern LCD but a heavier model, which may influence the assumptions about weight distribution and support reactions.
grey
Ok, i have a small (optional) project, to design a load bearing structure made of matchsticks. The structure must be able to withstand the load a computer monitor (i have a 17" one).
Now, the problem i am facing is how would the force (of gravity due to the mass of the monitor be distributed across the matchstick structure?
Note that, i intend to make use of 'matchstick trusses' (only two force members), with 'pin joints' (actually strings binding the match sticks).
I am actually totally clueless about this, as the problems i had encountered in high school assumed that all the weight acted through the centre of mass, which i don't think would be a valid assumption given the apparent non uniform distribution in the monitor.
ok...i know i wasn't much specific, but anyone?
maybe to elaborate a little, i want to find the transmission of forces at the monitor-structure interface.
Am i right to assume that the weight actually does act thru the centre of mass (approx) and then find the reaction of supports thru moments at each point of contact?
I don't know what your monitor (or truss) looks like, but my monitor is a flat 17 " screen supported on a round base about 9" in diameter, and it's load is supported pretty much uniformly at the base. In any case, in determining support reactions on your truss, you can do this by placing the monitor weight at the center of mass of the monitor, and determine the reactions by the static equiilibrium equations. However, in determining member forces, you should distribute the weight to the top joints beneath the monitor support as concentrated loads at those joints. You probably don't have to worry about truss member bending in between the joints since the monitor base is much more rigid than any individual truss member, so you still will only get axial loads in your members.
thanks a lot!
actually mines not a LCD, or any of the new types...its big and heavy, but i do get your point!
Thanks again!
  • · Replies 68 ·
