How Did Euler Link Complex Exponentials to Trigonometric Functions?
  • Context: Graduate
  • Thread starter Thread starter The_ArtofScience
    Euler
The discussion centers around how Euler linked complex exponentials to trigonometric functions, particularly in the context of solving the differential equation y'' + y = 0. Participants explore the historical and mathematical reasoning behind Euler's insights and the implications of initial conditions on the solutions.
  • Some participants question how Euler deduced that y = e^ix + e^-ix is a solution to the differential equation, given that it may not have been obvious at the time.
  • Others suggest that Euler likely recognized that the equation implies y'' = -y, leading him to consider functions whose derivatives are proportional to themselves, such as e^ax.
  • One participant proposes that the power series expansion of the exponential function reveals the relationship between complex exponentials and trigonometric functions.
  • Another participant discusses the transformation of the second-order differential equation into a first-order vector equation, highlighting the use of matrices and eigenvalues in the solution process.
  • Some participants emphasize the importance of initial conditions in determining specific solutions, noting that different conditions yield different trigonometric forms.
  • There is mention of the general solution to the differential equation being expressed in terms of sine and cosine functions, which are related to the complex exponential form.
  • Several participants engage in a debate about the rigor of using power series versus traditional methods for solving differential equations.
Participants express a range of views on Euler's reasoning and the methods used to derive solutions. There is no consensus on the best approach or the clarity of Euler's original insights, indicating that multiple competing views remain.
Some discussions highlight the limitations of relying on power series and the assumptions made regarding initial conditions. The historical context of Euler's work and the understanding of imaginary numbers at the time are also noted as relevant factors.
This discussion may be of interest to those studying differential equations, the history of mathematics, or the connections between complex analysis and trigonometry.
The_ArtofScience
In the general DE form, y"+y=0 and where the initial conditions are y(0)=2 and y'(0)=0, Euler realized that y(x)=e^ix+e^ix. How did he know that it's a cosine graph when there's no indication in the equation that any solution is possible? y= c1+c2=2 but y" gives 0.
Are you asking how he understood that the complex exponential is related to the the trigonometric functions?
Look at the power series of the exponential, and see that, with rearrangement, we must have:
[tex]e^{ix}=\cos(x)+i\sin(x)[/tex]
The power series for that identity does make sense, but I really wasn't asking about that. I'm wondering as to how he knew y= e^ix+e^-ix would be of use to y"+y=0
Well, presumably he first noticed separately that e^ix and e^-ix work. He may have found this simply by trying things, but more likely, he realized that the equation says that y''=-y, which says that the second derivative is proportional to the original function. One obvious thing to try would be a function whose first derivative is also proportional to itself (since this case is completely understood). The only function whose derivative is proportional to itself is e^ax, so we can see that an obvious guess is e^ax where a^2=-1, which gives us the two functions he found.
assume that y'' +y = o has a solution which is a lower series. then use the equation, plus perhaps the assumption that either y(0)=1 and y'(0) = 0, or vice versa, to deduce the form of the powers series.
Assuming we already know the solution to
y' = a x
is C e^{a t}
Then we can take:
y'' + y = 0
And rewrite it as a set of two equations:
y' = v
v' = -y
The reason we want to do this is that now we can define the vector:
F = {y,v}
so that
F' = {y',v'}
and we can define the matrix:
A = {{0,1},{-1,0}}
So that our second order equation becomes a first order vector equation:
F' = A F
Which has the solution:
F = C e^{A t}
where C is a vector, and the exponential of the matrix is defined by its power series:
e^{A t} = 1 + A + A^2 / 2 + A^3 / 3 ...
From here it is formal exercise to arrive at the solution, which uses diagonalizability (notice that plus and minus square roots of negative one are the eigenvalues of the matrix A).
You mean e^(ix)+ e^(-ix)
No, it doesn't. I have no idea what you mean by "y" gives 0".
Are you asking how Euler deduced in his time that y= e^ix+e^-ix satisfied the equation, when it did not appear obvious that any solution existed? That would be math history. I don't know for sure, but for one thing note that 'e' itself is also known as "Euler's constant". Presumably that means that he would have been sufficiently familiarised with it to realize that it satisfied the DE.
Thanks, I think I got it now. Setting y''=y allows everything to cancel out and form a cosine series when the initial condition y(0)=1 and y'(0)=0 is satisified. The -x on the right side would just equal to one when added to one. This was a lot more than I expected
y' = v
v' = -y
F = {y,v}
so that
F' = {y',v'}
A = {{0,1},{-1,0}}
F' = A F
F = C e^{A t}
I don't understand how you got A = {{0,1},{-1,0}}?
I think I understand the series now! e^ix+e^-ix is really 2cos(x) since cos(x)=1/2 (e^ix+e^-ix) and then differentiating substituting into the series and then ix^even gives the solution (!) Thanks people :-)
look, the equation itself says that y'' = -y, so if you differentiate the power series twice, you must get minus the original series.
comparing coefficients of the original series and the differentiated one, this says the coefficient of x^2 must be the constant coefficient divided by -2, and the coefficient of x^4 must be the constant coefficient divided by 4!, and the coefficient of x^6 is the constant coefficient divided by -6!,...thus if you assume also that y(0) = 1 and y'(0) = 0, you get precisely the power series of cos(x).
assuming as you did that y(0)= 2, y'(0) = 0, you get 2cos(x).
similarly, if y(0) = 0 and y'(0) = 1, you get sin(x).
another simple way to look at it (even though it isn't how Euler has written to look at it) is that the diff eq.:
[tex]\frac{d^2 y}{dx^2} = -y[/tex]
has, in real analysis, the general solution
[tex]y = A \cos(x) + B \sin(x)[/tex]
where A and B can be any numbers. the two terms are the two linearly independent solutions to the 2nd-order linear diff eq and there is some easy theorem that says that the sum of any two solutions is also a solution (and from that you can get that any constant-scaled solution is also a solution). there's another theorem that says the number of linearly independent solutions to an Nth-order diff eq is N.
without initial conditions, A and B can be any numbers, but with 2 initial conditions (or the same number of boundary conditions), both A and B can be determined to unique values.
with those initial conditions, A=1 and B=0 . if it were y(0) = 1 and y'(0) = i, which you get for
[tex]y(x) = e^{\mathrm{i} x}[/tex]
then A = 1 and B = i .
i know this isn't how Euler's formula isn't first presented, but i liked this diff eq presentation (and proof, such as it is) the best.
i am proving what you are taking for granted.
what, specifically, is taken for granted?
can not mathematicians, who are post-Newton and post-Leibniz, but who have never dealt with the concept of imaginary numbers, are they not capable of doing ordinary, homogeneous diff eqs such as
[tex]\frac{d^2 y}{dx^2} + y = 0[/tex]
and getting the general solution
for undetermined A and B?
can they not apply 2 independent initial conditions to impose constraints on A and B so that they must take on particular values in order for the 2 initial conditions to be satisfied?
you don't need to go and use power series to do that. and, IMO, the power series method is a little uglier, and i don't see it as more rigorous. it's just another way to do it, given the "assumptions" we learn from calculus.
now, when you apply it to solving Euler's formula
[tex]y(x) = e^{\mathrm{i} x} \ = \ ??[/tex]
where you want explicit real and imaginary parts to y(x), then we are taking some things "for granted". like i2 = -1 and then otherwise, we treat i just like we have the real numbers where axioms like the commutative, associative, and distributive properties apply. does your proof prove those basic axioms? i don't think so, like mine, you are assuming the same axioms.
and, because we're treating i as some other general number (but with the specific property that i2 = -1 ), we're saying that the results learned from calculus (like what the derivative of eax is), we are able to set up that diff eq and the initial conditions to derive Euler's formula.
wonk, you be the math prof, and i am just a Neanderthal electrical engineer (who does signal processing for a living and has some university teaching experience, too), but like the Dirac delta thing, here is another place where mathematicians and electrical engineers just might have different valid ways of looking at it. i don't think, given what we learn in calculus and previous math courses, that the power series method of solving that particular diff eq is any more rigorous than using the known properties of the trig functions cos(.) and sin(.).
Sorry about my simplistic view of things, but I think about it like this:
We want to solve y"+y=0
So, if we add the second derivative of the function to itself, it must equal zero. We know the second derivative of sine or cosine is minus itself, therefore they both satisfy y"+y=0. It is a simple matter to go from this to complex exponentials.
You can go on to look at uniqueness and all that other jazz, but I do not know what level you're at.
that is, if you have already established a relationship between complex exponentials and the sin(.) and cos(.) functions. if you haven't established that relationship, there are a few different ways to do it. it seems the most common is to look at the power series of eix, cos(x), and sin(x), and when i is the imaginary unit (so that i2=-1), you can see that the series for cos(x) and i sin(x) add up to the series for eix (and then conclude that they are the same functions).
but, it's not necessary to use power series to do that. the Wikipedia article on Euler's formula shows two other valid proofs other than the power series method. one is noting what you, qspeechc, did above for the solution to y"+y=0. but it also notes that eix is a solution and since
y(x) = eix
and
y(x) = cos(x) + i sin(x)
are both solutions to y"+y=0 and both satisfy these two initial conditions:
y(0) = 1
y'(0) = i
that is enough to say that they are the same. it's an alternative proof to Euler's formula which is why i took a little exception to wonk's implication that the power series method proves something that is taken for granted using the diff eq method here.
  • · Replies 18 ·
  • · Replies 0 ·
11K
