| Thread Closed |
Cylinder head pressure at expansion phase |
Share Thread |
| May20-08, 10:10 AM | #1 |
Does anyone know what the pressure is inside the cylinder of an internal cumbustion gasoline engine at the expansion phase? ive been doing some research and ive seen answers ranging from 200psi to 600psi. seems like a significant range, does anyone know where i can get somewhat more accurate information? i dont have a specific engine in mind, But i have to assume there is an industry standard for this pressure.
| May20-08, 11:22 AM | #2 |
| May20-08, 11:36 AM | #3 |
thanks for the reply. is there a way to look it up based on the specific engine - is there a table or website that quotes these measurments?
| May20-08, 11:56 AM | #4 |
This is a pretty rare measurement because it is difficult to get. Overall, the pressure is not constant during the power stroke (obviously) so what you might find is a peak pressure or average pressure. It's not really a factory-supplied metric.
I would guess the peak pressure in an engine is an order of magnitude greater than what you heard before which could be an average of some kind (200-600psi). High-compression engines could have just a test air compression of 150psi or more, so during a power stroke I would not be suprised if during combustion the pressure spiked to thousands of psi, considering the amount of torque engines can put out. |
| May20-08, 12:35 PM | #5 |
Thanks for the info. i didnt think it would be thousands of psi, and you are correct i am curious of the peak pressure, not the average. i was thinking 600psi might be closer to correct, because ive seen references that the compression phase (which seems to be documented better) is 150-200psi, so i assumed with ignition, the explosion would create a significant increase over the compression pressure. I guess i just didnt account for the explosion creating that significant of an increase.
I appreciate your help in trying to figure this out. Thanks! |
| May20-08, 12:40 PM | #6 |
Well, I did a little searching of my own and it seems you are correct in assuming peak pressures will be around 200 psi. High performance engines may be higher, but probably not more than 400 psi or so...
| May20-08, 01:41 PM | #7 |
WOW....thanks for looking into it, that is really nice of you. do you have a reference i can take a look at?
| May20-08, 03:00 PM | #8 |
I looked around at a couple of different sites and discussions. One interesting paper I found here discusses measuring the pressure in a Skoda engine with about 67 hp:
http://www3.fs.cvut.cz/web/fileadmin...gujevac-Bl.pdf I also ran accross a paper from Harvard that discusses a computational model used to try and estimate the pressure in a spark ignition ICE. The calculations are then compared to actual measurments on an engine. http://www.hcs.harvard.edu/~jus/0303/kuo.pdf Both papers end up measuring and calculating a peak pressure in the cylinder of about 200 psi. |
| May20-08, 03:11 PM | #9 |
Your figures are of the right kind of order. I'd work on 30bar (435psi) being a general maximum peak cylinder pressure for a typical automotive SI engine.
| May22-08, 01:56 PM | #10 |
From doing some digging around the web, I found that most engines are designed for PCP to occur around 10° - 15° ATDC. If we know the torque and the stroke we can work backwards to determine the amount of pressure the piston sees.
Example L91 (GM 1.6L) engine: Bore & Stroke: 3.11" & 3.21" CR: 9.5:1 Torque Peak: 107 Ft-Lbs @ 3600 RPM Take the peak torque of 107 Ft-Lbs, divide that by half the stroke in feet, 0.13375' we get 800 POF (pounds of force). If PCP occured at 90° ATDC than we would only need 105.3 PSI to generate full torque. However as stated above engines are designed for PCP at 10° - 15° ATDC at which point we take the sin(10°) and get: 606.5 PSI or sin(15°) and get: 406.9 PSI. So with this particular engine that is our range between 406.9 and 606.5 PSI. |
| May22-08, 02:50 PM | #11 |
Hmm, after re-reading the Harvard paper dealing with cylinder pressure, it would appear the maximum pressure in the cylinder at full load at 4000 rpm was about 5320 kpa, which equates to 771 psi, and the peak pressure occured at 20 degrees after TDC.
| May22-08, 02:58 PM | #12 |
Recognitions:
You're ignoring the mechanical effects of the pushrod linkage. You're assuming that the torque rating (which should be a time-average) is the same as the instantaneous torque at ignition. You're also ignoring that the torque rating is the net torque and that while one cylinder is firing, other cylinders are getting compressed, going through power strokes, or venting exhaust. (The L91 is a 4-cylinder engine.) |
| Jun17-08, 03:51 AM | #13 |
hello ....can the people who reply later give me the following information or any help regarding this ? .....i want to know the pressure at which the exhaust waste gases leave the IC Engine chamber en route to the Three way catalytic converter ......
| Jun17-08, 03:58 AM | #14 |
can someone here tell me the pressure at which the exhaust waste gases leave the IC Engine chamber en route to the three way catalytic converter
| Jun17-08, 07:49 AM | #15 |
NateTG has a very lucid point. The losses are enormous and I think unaccountable. I think also that there are throttling losses accosiated with actual running conditions. However, minimum pressure should be able be to calculated if losses are put aside for the moment. Then accountable losses just add up to more pressure.
| Jan6-09, 06:35 AM | #16 |
any idea , what is the material inside a internal combustion engine need to be change when i change the gasoline fuel into hydrogen fuel.? Also what is the lubricant that will suitable for this hydrogen fuel. thx
| Jan6-09, 12:35 PM | #17 |
| Thread Closed |
Similar discussions for: Cylinder head pressure at expansion phase
| head loss due to sudden expansion | Mechanical Engineering | 11 | ||
| dynamic head, pressure drop formulas? | Mechanical Engineering | 5 | ||
| Engine cylinder pressure | Mechanical Engineering | 15 | ||
| pressure and gas expansion | Advanced Physics Homework | 9 | ||
| Quantum Phase Compactification via Spacetime Expansion | General Physics | 5 | ||
