Thermodynamics - efficiency of power plant
The discussion revolves around the thermal efficiency of a power plant that generates heat energy from nuclear reactions, producing steam to drive a turbine. The problem includes calculating maximum and actual efficiencies, as well as determining the exit temperature of cooling water after interacting with the steam condenser.
  • Mixed
  • Participants explore the calculation of maximum thermal efficiency using the Carnot efficiency formula and actual efficiency based on power output. There are attempts to calculate the exit temperature of cooling water, with some questioning the realism of the temperature increase observed.
Some participants have confirmed calculations and provided feedback on specific heat values. There is ongoing exploration of the arithmetic involved in determining the exit temperature of the cooling water, with differing opinions on the accuracy of initial calculations.
Participants note discrepancies in specific heat values and express uncertainty about the assumptions made regarding temperature changes in the cooling water. There is mention of potential errors in calculations due to misinterpretation of values.
fredrick08
a power plant generates 2000MW of heat energy from nuclear reactions in the reactors core. this energy is used to boil water and produce height pressure steam at 300degreeC. the steam spins a turbine, which produces 700MW of electric power, then the steam is condensed and the water is cooled to 30degreeC before starting the cycle again.
a.what is the max possible thermal efficiency of the power plant?
b.what is the plants actual efficiency?
c.cooling water from a river flows through the condenser at the rate of 1.2x10^8L/hr. if the river water enters the condenser at 18degreeC what is is exit temperature?
efficiency(carnot)=1-(Tc/Th)
efficiency=Wout/Qh
Q=mc[tex]\Delta[/tex]T
a. 1-(303/573)=47%
b. Wout/Qh=Power/(Qh/t)=7x10^8/2x10^9=35%
c. now the others were easy (i think lol) this one kinda gets me) what I've done is,
Power=(Qh/t)-(Qc/t) therefore (Qc/t)=(Qh/t)-Power=1.3x10^9W
then 1.2x10^8L/hr*3600s=33333.33L/s
so Q=mc[tex]\Delta[/tex]T
so Tf=(Q/(mc))+Ti=(1.3x10^9/33333.33*4190)+291=44.2degreeC
now i seen this same question in another thread, but their specific heat was 4160? and they also did something weird, i don't understand... but i don't think mine is right, can anyone help me, or confirm that i am right?
anyone have any ideas?
Your analysis and answer is correct. You can look up the specific heat of water. It is one calorie/gram K or 4186 J/Kg K at 20C. There is some temperature dependence on this but I wouldn't worry about it.
AM
ok, thankyou very much for your confirmation = )
ok, I am just kinda thinking back on my work now, but does 44.2degreeC sound realistic? the river water goes in at 18degreeC and gets heated by the condensing steam then leaves but would it really heat up by 26degreeC? so that river water doesn't then cool to 30degreeC and goes in the cycle does it? i guess that kinda makes sense...
anyone?
Check your arithmetic. I get an increase of 9 degrees for a final temperature of 27 degrees.
3.3 x 10^4 Litres pass through each second and the plant must release 1.3 x 10^9 Joules per second. So each litre of water must absorb 3.9 x 10^4 Joules. Since absorption of 4.2 x 10^3 Joules raises the temperature of one litre by 1 degree, the water temp. rises 9 degrees when absorbing this heat.
AM
yes ok i completely understand wat ur saying, cept where does the 4.2x10^3 J come from, how do i get it? and how would i write that? since its not really using the formula...
omg, I am sooo srry, stupid dyslexic me, c as 1490, instead 4190... srry, ok now i g 27.3degeeC, thanks heaps
  • · Replies 20 ·
14K
9K
18K
