E.m.f across the ends of a rod rotating in a magnetic field
The discussion focuses on deriving the electromotive force (E.m.f) across the ends of a rod rotating in a magnetic field, specifically using the Lorentz force equation. The formula established is |\epsilon| = B \omega r^2, where B is the magnetic field strength, ω is the angular velocity, and r is the distance from the center of rotation. The analysis involves calculating the Lorentz force acting on electrons within the rod and integrating to find the total E.m.f. The conclusion emphasizes that the electric field generated balances the magnetic force on the electrons, leading to the derived E.m.f.
  • Understanding of Lorentz force and its application in electromagnetism
  • Familiarity with the concepts of electromotive force (E.m.f) and electric fields
  • Basic knowledge of calculus, particularly integration
  • Concept of angular velocity and its relation to linear velocity in rotating systems
  • Study the derivation of the Lorentz force equation in detail
  • Learn about the principles of electromagnetic induction and Faraday's law
  • Explore the relationship between electric fields and magnetic fields in rotating systems
  • Investigate practical applications of E.m.f in generators and motors
Physics students, electrical engineers, and anyone interested in the principles of electromagnetism and their applications in rotating systems.
rohanprabhu
I am trying to derive the formula for E.m.f across the ends of a rod rotating in a magnetic field when the field is perpendicular to the plane of rotation:
[tex] |\epsilon| = B \omega r^2[/tex]
using the Lorentz Formula only. Suppose, there is a rod of length 'R'. Let, 'n' be the no. of electrons per unit length. Let, at a distance 'r' from the center of rotation, there be a small length element dr. The no. of electrons in this length element is [itex]ndr[/itex]. Also, the velocity, [itex]v = r\omega[/itex] is perpendicular to the field always as it lies in the plane of rotation of the rod. Hence, the Lorentz force here is given as:
[tex] dF = en r\omega B dr[/tex]
What do i do after this? Do integrate it? This integral only talks about a 'net force' on all the electrons. How do I use it to compute the e.m.f across the two ends? Do I first compute work using [itex]\int W = \int F.dr[/itex] and the differentiate w.r.t charge. But, what charge is the Work a function of?
I think the EMF will be [tex]\frac{1}{2}[/tex] B [tex]\omega[/tex] r[tex]^{2}[/tex]
The magnetic force on every electron is balanced by the force due to electric field. Thus
eE = Bev = Be [tex]\omega[/tex] r
and d[tex]\xi[/tex] = Edr
