What is the composition of exhaust fumes from petrol and diesel engines?
The composition of exhaust fumes from petrol and diesel engines varies significantly, with both types primarily emitting nitrogen (N2), oxygen (O2), carbon dioxide (CO2), and water vapor. Petrol engines typically operate with varying levels of carbon monoxide (CO) depending on the air-fuel ratio, while diesel engines are characterized by higher particulate matter, including soot and sulfur compounds. Key pollutants such as sulfur dioxide (SO2), nitrogen oxides (NOx), and hydrocarbons (HC) are present in both engine types but in variable quantities, often measured in parts per million (ppm) rather than percentages. Understanding these emissions is crucial for evaluating environmental impact and engine performance.
  • Knowledge of internal combustion engine operation
  • Familiarity with combustion chemistry
  • Understanding of air-fuel ratios
  • Awareness of environmental regulations regarding emissions
  • Research the impact of air-fuel ratio on emissions in petrol engines
  • Study the formation and reduction of nitrogen oxides (NOx) in diesel engines
  • Explore methods for measuring particulate matter in exhaust emissions
  • Investigate the effects of low sulfur fuels on diesel engine emissions
Environmental scientists, automotive engineers, and policymakers focused on emissions regulations will benefit from this discussion, as it provides insights into the chemical composition of exhaust gases from petrol and diesel engines.
Aquafire
In regards to two types of engines..
What gases (by percentage) are to be found in conventional petrol driven internal combustion engines, such as found in cars ?
What gases (by percentage) are to be found in conventioanl diesel driven internal combustion engines, such as found in trucks ?
I have tried to search for an accurate breakdown of the two, but ploughing through the internet has left me more confused than clarified.
So, if any of you guys knows for sure...then please help me out..
Thanks in advance..
Aqua
Ps...
Mods, if you feel that this thread should be in chemistry, feel free to move it...
Depends quite a lot on the engine type, purpose, and how it's being run. This is a complex field, and (as you're probably aware), a huge amount of engineering work is done in this field.
In brief, there are thousands of different chemicals found in engine-out exhaust gases for both Diesel and petrol engines. The bulk of the gaseous emissions are made up of N2, O2, CO2, and water vapour (and maybe some CO). Typically, the N2 level will not change much before/after the combustion event. CO2, CO and O2 levels are all relative, and depend on the air fuel ratio. Lean operation will give high O2, moderate CO2, and low CO; where rich operation will give very low O2, moderate CO2, and very high CO.
Now, SO2, NOx and hydrocarbons are all pretty much universally present, but in very variable quantities (and these quantities are measured in ppm, rather than %). Sulphur compounds are a feature of sulphur in the fuel (which is why you now see low sulphur fuel), NOx is from atmospheric air, and is a feature of high peak cylinder temperatures; and HC are a result of incomplete combustion for whatever reason. Other components (notably alcohols and aldehydes) are present in smaller quantities still.
Diesel engines typically have high levels of particulate matter within the exhaust (as compared petrol engines). This particulate matter comprises of soot and sulphur compounds (from lube oil and fuel), all kinds of organic matter, and varying amounts of metals. Again, these are in tiny amounts compared with the main gaseous components.
Does this help?
24K
37K
  • · Replies 21 ·
