Rotational Dynamics/Angular Momentum
  • Context: Undergrad
  • Thread starter Thread starter discoverer02
    Momentum Rotational
The discussion centers on the concepts of rotational dynamics and angular momentum, particularly focusing on the challenges faced by students in understanding these topics. Participants express a desire for clearer explanations and resources to aid in their comprehension of the underlying principles rather than just procedural knowledge.
  • Homework-related
  • Some participants express a need for clear and accessible reading materials on rotational dynamics and angular momentum.
  • One participant discusses the fundamental law of rotational motion, relating angular momentum and torque through differentiation.
  • Concerns are raised about the intuitiveness of the cross product and its physical interpretation in the context of angular momentum.
  • Participants describe confusion regarding the relationship between the motion of a tire and its rotation, particularly the concept of instantaneous velocity at different points on the tire.
  • One participant suggests visualizing the tire's motion as a series of instantaneous snapshots to understand the velocity distribution across its surface.
  • Another participant proposes simplifying the problem by considering a rolling hoop instead of a tire to clarify the concept of velocity in a co-moving reference frame.
Participants generally agree on the challenges of understanding rotational dynamics and the need for better resources. However, there are multiple competing views on the interpretation of rotational motion and the cross product, indicating that the discussion remains unresolved.
Participants express varying levels of difficulty with specific concepts, such as the cross product and the instantaneous motion of rotating objects. The discussion reflects a range of assumptions and interpretations that are not fully reconciled.
discoverer02
I'm at the end of a 1st semester college Physics class. I was handling it pretty well until we got to Rotational Dynamics/Angular Momentum. I could and will probably survive by practicing problems and recognizing the mechanical steps required to solve these certain types of problems, but I really want to acquire a fundamental understanding of the concepts involved rather than just be able to repeat the steps required.
Can anyone recommend some good, clear, easy to understand reading on these topics?
Thanks.
Fundamental law of rotational motion is obtained by differentiating the definition of angular momentum L=[rxp] over time which results in dL/dt = T, where T=[rxF] is labeled as "torque". So, whatever the torque vector direction is, the angular momentum vector changes in that direction.
Thanks.
I will be watching to see if anyone does come up with some (especially online) explanatory reading. Other people could probably use it too.
Many people are impeded by the vector "cross product".
How do you feel about cross product? Is it intuitive for you or does it put you off?
Some people are slowed down by wondering WHY a rotation in a plane should be represented by a vector which is perpendicular to the plane and whose length is an index of the rate of rotation.
and direction of rotation.
Or, when angular momentum is measured instead of simple rotation rate, the length of the vector reflects the amount of angular momentum about that axis. and direction.
Discoverer02, you haven't said where the difficulty is, for you.
Different sorts of people get stuck on different things.
I can only GUESS that you are having problems with cross product and the algebra of cross products and you are wondering what the reason for this way of representing rotation and angular momentum. But there may be other things.
It is not unusual for first year students to by frustrated with these things and actually takes some work and practice---hard work and hard practice---to get thru it. But then intuitive understanding will come. As long as the prof is not a jerk.
Originally posted by marcus
Some people are slowed down by wondering WHY a rotation is a plane should be represented by a vector which is perpendicular to the plane and whose length in an index of the rate of rotation.
and direction.
Actually, rotation in a plane isn't represented by a vector orthogonal to the plane and so on... it's represented by a 2-form created from the wedge product of two 1-forms "pointing along" each axis of the plane... and it just happens that in Euclidean 3-space, such an object is is indistinguishable from a vector.
- Warren
I find a few different things confusing. Cross product is one of them. I don't, however, have a problem with the mechanics of the algebra. That's pretty straight-forward. The whole notion of the cross product, and just what exactly r x p physically is. isn't clear to me. Other little things like the velocity at the top of a tire being twice as great as the velocity of the center of mass and how the velocity of the tire at the bottom is temporarily zero is also a little hard to understand. Because I don't find some of it intuitive, it's difficult to keep all the concepts straight and know when and sometimes how to apply them.
So I'm looking for something that explains the topic as a whole and puts everything together, and not just a specific piece.
To undertsand tire, move with it. Then in your system of reference tire center is not moving (0), the tire bottom is moving back (i.e. with -v versus you) and the tire top - forward (with +v). Now return back to non-moving system (=add v to all), and you'll get 0 at bottom, v at center and 2v at top.
(Called addition of velocities due to coordinate transformation from moving to non-moving system).
In non-moving system tire is seen as rotating around its bottom ( instant axis of rotation constantly moving forward with rire).
Originally posted by Alexander
In non-moving system tire is seen as rotating around its bottom ( instant axis of rotation constantly moving forward with rire). [/B]
This is the part that I can't comprehend -- the notion that the tire is rotating around its bottom when it's moving forward and spinning around it's center.
If we are lucky someone will show up who knows a good online or other textbook chapter on rotation/ang.mom.
But until that happens...
The picture of the tire is an instantaneous one. Pretend you had a camera that could take a picture of the tire just as it rolled past you and that it would show, painted on at each point, a little arrow that is the instantaneous velocity of that point-----at the instant the shutter clicked.
The snapshot of the tire would be all covered with little arrows.
The point touching the road would have a zerolength arrow.
The point at the top of the tire would have a horizontal forwards pointing arrow twice the length of the one at the center of the hubcap
Up the center of the picture would be layer after layer of arrows getting longer the higher off the road, till reaching the top of the tire. Their length would be proportional to height.
Just like on a regular stationary turning wheel the speed of a point is proportional to how far out from the center.
None of the arrows in the snapshot are correct except for that one instant (well, the center of hubcap arrow stays the same but the rest dont)
The very next instant you would need to erase them all and draw the picture over, because a new point would be touching the ground. But the picture would look the same! It will always look,
for just that one instant, like rotation around the point touching the ground.
One can ask, well OK but what is the big deal? why should a physics teacher want me to realize this. But as long as one doesn't get off onto that and just looks at the tire it is not such a hard picture to get. Actually I like it---it helps solve something in an elegant way, doesn't it? Did this discussion help at all?
Discoverer, imagine rolling hoop (ring) instead of tire (for simplicity). In co-moving reference system the hoop is simply rotating, thus each point of hoop has velocity v directed tangentionally. Now take any point on a hoop and add to this velocity same velocity vector v but directed always forward. The vector sum of the two vectors will be the same as the velocity vector of rotating around bottom point tire.
Thanks marcus. I can see the importance of the point and how conceptually what happens about this point would be considered rotation.
My pleasure, discoverer! Sorry none of us came up with an good online tutorial on rotation-physics! I should know a link like that but unfortunately don't. Hang in there. Guess it must be final exam time. Try PF again when you have more free time, maybe we will have suggestions then.
BTW do you have any specific areas of puzzlement
you want to talk about-----I don't seem to have a URL
for a general rotation-physics tutorial
seems we are going in circles here.
my physics professor says " I always know when someone is going to blow the test (when they are taking it) when i see them staring at their left hand"
  • · Replies 35 ·
