(h,k) of circle given D from parabola
  • Context: Undergrad
  • Thread starter Thread starter fedaykin
    Circle Parabola
The discussion revolves around finding the center of a circle inscribed in the parabola y=x^2, specifically determining the coordinates (h, k) of the circle given its radius and the parabola's equation. The scope includes calculus concepts, particularly derivatives and tangent lines.
  • Exploratory, Technical explanation, Homework-related, Mathematical reasoning
  • One participant expresses uncertainty about how to approach the problem, considering using derivatives to find a tangent line and equating distances, but is unsure about the point of tangency.
  • Another participant provides the equation of the circle and notes that its center lies on the y-axis, suggesting that the x-coordinate is zero and emphasizing the need to find points of intersection with the parabola.
  • There is a discussion about the meaning of "gradient," with one participant clarifying that it refers to dy/dx and not a vector field, while another expresses confusion about the terminology.
  • A later reply mentions that while implicit differentiation is not necessary, it could be beneficial for solving the problem.
Participants do not reach a consensus on the best approach to solve the problem, and there is a mix of understanding regarding the mathematical concepts involved.
There are limitations in the discussion regarding the assumptions about the tangency of the circle and parabola, as well as the specific points of intersection that need to be determined.
fedaykin
I'm studying up for calculus I this fall, and I found a problem I can't solve.
The figure (shown in attachment) shows a circle with radius 1 inscribed in the parabola y=x^2. Find the center of the circle.
So far, I have no idea. I could use the derivative to find a tangent line, then set the two distances equal to each other and solve for y, but I have no idea at what point the circle is tanget, or even if it is (at least with an analytic proof). Since I don't have the circles equation, I can't solve for points common to both equations.
The equation of the circle is [tex]x^2 + (y-y_0)^2 = 1[/tex]. You can see that the centre of the circle is on the y-axis, meaning to say it's x-coordinate is zero y0 is the y-coordinate of the centre.
Where y=x^2 and the circle intersect, the gradient of the tangent line passing through the points of intersection are the same. dy/dx for both the parabola and the circle through these points are the same for some values of y1,x1. You also know that you to find where the curve and the circle intersect, you only need relate the equation of the circle with that of the parabola.
When you mention gradient, I hope you're not referring to that vector field stuff referred to by the link. It will quite some time before I'm capable of understanding that.
Oy, nevermind, I'll read up on implicit derivation. It took me a while to understand that.
Thank you very very much.
No, that has nothing to do with grad. Gradient here just refers to dy/dx. And, yeah, while implicit differentiation is not necessary, it does help a lot here.
