Induced Electric Fields of metal ring
The discussion focuses on the induced electric fields in a metal ring with a diameter of 4.50 cm placed in a magnetic field of 1.12 T that decreases at a rate of 0.250 T/s. The induced electric field in the ring is calculated to be approximately 2.8 mN/C. The current flows in a clockwise direction when viewed from the south pole of the magnet, as the induced magnetic field opposes the decrease in magnetic flux, consistent with Lenz's Law.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Knowledge of Lenz's Law
  • Familiarity with magnetic flux calculations
  • Basic proficiency in calculus for rate of change
  • Study Faraday's Law of Electromagnetic Induction in detail
  • Learn about Lenz's Law and its applications in electromagnetic systems
  • Explore magnetic flux calculations and their implications in circuit design
  • Investigate the relationship between induced EMF and electric fields in conductive materials
Physics students, electrical engineers, and anyone interested in the principles of electromagnetism and their applications in real-world scenarios.
aznkid310
A metal ring 4.50 cm in diameter is placed between the north and south poles of large magnets with the plane of its area perpendicular to the magnetic field. These magnets produce an initial uniform field of 1.12 T between them but are gradually pulled apart, causing this field to remain uniform but decrease steadily at 0.250 T/s.
(a) What is the magnitude of the electric field induced in the ring?
(b) In which direction (clockwise or counterclockwise) does the current flow as viewed by someone on the south pole of the magnet?
Do i need to do anything with the initial B value?
Change in flux dB/dt = -0.25t?
Or is it dB/dt = 1.12 - 0.25t?
a) d[phi]/dt = (dB/dt)*Acos(0) = (-0.250)*(pi(2.25*10^-2)^2) = -3.98*10^-4 Wb
E = (1/2r*pi)*(d[phi]/dt) = -2.8*10^-3 N/C
b) Clockwise?
Hi aznkid310,
I don't believe your answer to part b is correct. Can you explain your reasoning for that part?
induced emf = - (change in magnetic flux)
Since magnetic flux is decreasing, an induced magnetic field opposite to that must be created to counteract this change in flux. Is my reasoning off?
Also, is part (a) correct?
Your answer to part a looks right to me (except they want the magnitude of the field, so you don't need the negative sign).
The induced magnetic field will be in the direction to oppose the change. Since the magnetic flux from the magnets is decreasing, the induced magnetic field will be in the same direction as the magnet's field. Does that make sense?
Ah that makes sense. It would oppose only if the magnetic flux is incresing right?
It always opposes the change, so if the magnetic flux is increasing, then yes, the induced field will be in the opposite direction as the external flux.
  • · Replies 18 ·
