Signs Before 9.8 m/s^2 in Motion Questions
  • Thread starter Thread starter 9giddjl
    Motion
The discussion centers on the correct usage of the gravitational acceleration constant, 9.8 m/s², in projectile and straight-line motion problems. The sign of 9.8 m/s² depends on the chosen coordinate system: if upward is positive, then the acceleration due to gravity is negative when an object is falling and positive when thrown upwards. Conversely, if downward is positive, the signs reverse. Consistency in sign usage throughout the problem is crucial for accurate results.
  • Understanding of basic physics concepts related to motion
  • Familiarity with projectile motion equations
  • Knowledge of coordinate systems in physics
  • Ability to draw and interpret motion diagrams
  • Research how to set up coordinate systems in physics problems
  • Learn about the equations of motion for projectile motion
  • Explore the concept of free fall and its implications on sign conventions
  • Study examples of motion diagrams to visualize direction and acceleration
Students studying physics, educators teaching motion concepts, and anyone seeking to clarify the application of gravitational acceleration in various motion scenarios.
9giddjl
Um this isn't really a homework question, just a general question in relation to the sign you put in front of 9.8 m/s^2?
I don't know, when do i put a negative or positive in front of it when doing projectile motion and straight line motion questions?
Do you put negative in front of 9.8 m/s^2 when the object is being thrown up or do you put positive?
I just don't know.
If anyone could help me I'd be ever so grateful:)
Thankyou very much:)
It depends on how you model the question. Do you take direction upwards to be positive or negative? If let the skyward direction be positive, then you take -g and +g when you take downwards to be positive. Do this consistently throughout the question, don't switch signs.
This all depends on the coordinate system that you choose. A good idea before starting a question is to set up your coordinate system such that it will make your solution simpler. Make sure that you be consistent though in your signs and it helps to draw a diagram to be reminded of your choice.
With that being said, let's assume you let the y-axis point up, with an object falling down, you'd put in the negative sign (and positive if thrown up). However, if you choose your axis to point down, a falling object will have a positive sign and negative if thrown up.
So once again it all has to do with your coordinate system and how you set it up.
Hope this helps.
Cheers CB
  • · Replies 30 ·
