Length of Spring: How Can the Unstretched Length Be Determined?
  • Thread starter Thread starter ttiger2k7
    Length Spring
The problem involves determining the unstretched length of a spring in a system where a load of weight 400 N is suspended from it, along with two cords attached to blocks of weights 3W and W. The spring constant is given as 800 N/m.
  • Participants discuss the relationship between the forces acting on the spring and its unstretched length, with one participant noting the use of Pythagorean theorem to find a length in the system. There is also mention of considering the spring force equation and whether it can be expanded to include initial and final values.
The discussion includes various attempts to analyze the problem, with some participants exploring the geometric aspects and others focusing on the spring force equation. There is no explicit consensus, but guidance is being offered on how to approach the problem.
Participants question the relevance of certain measurements and the implications of forces acting on the spring, indicating a need for clarity on the unstressed state of the spring.
ttiger2k7
[SOLVED] Length of Spring
A load of weight 400 N is suspended from a spring and two cords that are attached to blocks of weights 3W and W as shown. Knowing that the constant of the spring is 800 N/m, determine (a) the value of W, (b) the unstretched length of the spring.
http://img406.imageshack.us/img406/472/13213uv7.jpg
[tex]F_{s} = -k x[/tex]
I have already worked through part (a), getting 62.8 N for W and in the process I got 281.712 for the [tex]F_{s}[/tex] of the system above.
Now from the picture above, I can figure that the length AB is 1110 mm using Pythagoreans. Whether that is relevant or not to figuring (b) out, I am not sure. I'm thinking that I need to find what the [tex]F_{s}[/tex] would be if there were no forces acting on the spring.
I would look at the relevant equation and attempt to determine if it can be expanded to include initial and final values.
You can determine angles using SOH CAH TOA. From there you can use components to work out your answer more precisely.
double post...
Thanks, I got it!
10K
15K
