Prove f(x)=g(x) - Essentials of Calculus p.45, Problem 11
  • Thread starter Thread starter razored
The discussion revolves around proving the equality of two piecewise functions, f(x) and g(x), as presented in a self-study calculus book. The functions are defined over different intervals, and the original poster expresses uncertainty about how to begin the proof.
  • Participants suggest breaking down the proof by examining the conditions under which f(x) is defined and comparing them to g(x). There is a focus on evaluating g(x) in the same intervals as f(x) to establish equality.
Some participants have provided guidance on how to approach the proof by considering the cases defined by f(x). The conversation reflects a mix of attempts to clarify the problem and suggestions for structuring the proof, but there is no explicit consensus on a complete solution.
The original poster indicates that this is a self-study problem, which may imply constraints on the type of assistance expected. There is also a mention of a desire for a more profound explanation, highlighting the need for clarity in understanding the proof process.
razored
This not homework(self-study book). I do not know where to begin to prove this. This is from "Essentials Calculus" page 45, problem # 11
[tex]f(x) = \left\{ \begin{array}{rcl}{-1} & \mbox{if}& -\infty < x < -1, \\ x & \mbox{if} & -1\leq x\leq1, \\1 & \mbox{if} & 1 < x <\infty ,\end{array}\right[/tex]
[tex]g(x) = \frac {1} {2} |x+1 | - \frac {1}{2}|x-1|[/tex]
Prove that [tex]f(x)\equiv g(x)[/tex]
Latex is awesome :biggrin: First time using it here!
where's your attempt at the proof?
But consider what g(x) is for the conditions for f(x)
Glad you like latex. But, yes, as rock.freak667 points out, split into the three cases that define f.
I don't understand ... "split into the three cases that define f." the cases are listed.
I have no idea where to begin to prove this; a profound explanation would be helpful.
He means split g(x) into the three cases that define f(x). You must show that when x < -1, g(x) = -1, when -1 < x < 1, g(x) = x, and when x > 1, g(x) = 1.
Consider this simpler problem:
[tex]f(x) = \begin{cases}-x & \text{if}\ x < 0 \\ \phantom{-}x & \text{if}\ x>=0 \end{cases}[/tex]
[tex]g(x) = |x|[/tex]
For [itex]x>=0[/itex], [itex]g(x)=|x|=x[/tex]. For [itex]x<0[/itex], [itex]g(x)=|x|=-x[/tex]. In both cases, [itex]g(x)=f(x)[/itex]. The functions are identical for all x.<br /> <br /> You can do the same thing with your [itex]f(x)[/itex] and [itex]g(x)[/itex]. In particular, what does [itex]g(x)[/itex] evaluate to in each of the three regions?[/itex][/itex]
If you want to see how to write it formally out you would do something like:
Case 1: Suppose x < -1 then g(x) = ... = f(x)
Case 2: Suppose x > 1 then g(x) = ... = f(x)
Case 3: Suppose -1<=x<=1 then g(x) = ... = f(x)
Two functions f,g are equal in an interval I if f(x)=g(x) for every x in I. (In your case your interval is all real #'s.)
Ok. Figured it out, thanks!
