Product Rule for Derivatives of Theta and Time Functions
  • Context: Graduate
  • Thread starter Thread starter Ultimâ
    Derivative Fun
The discussion revolves around the application of the product rule in the context of derivatives involving functions of theta and time, specifically focusing on the expression \(\frac{\delta}{\delta \theta}(\dot{\theta} \cos\theta)\). The scope includes calculus of variations and the interpretation of the derivative operator.
  • Some participants propose that the product rule is applicable to the expression involving \(\dot{\theta}\) and \(\cos\theta\).
  • One participant questions whether \(\frac{\delta}{\delta \theta}\) should be interpreted as a derivative or as "total variation," suggesting a different approach to the problem.
  • Another participant expresses concern that \(\dot{\theta}\) may not be independent of \(\theta\), indicating a potential complication in applying the product rule straightforwardly.
  • A participant mentions that the total variation approach is part of a Jacobian, implying a connection to derivatives but expressing uncertainty about its application in this context.
Participants do not reach a consensus on the interpretation of the operator \(\frac{\delta}{\delta \theta}\) or the applicability of the product rule, indicating multiple competing views and unresolved questions.
There are limitations regarding the assumptions about the independence of \(\dot{\theta}\) from \(\theta\) and the interpretation of the derivative operator, which remain unresolved in the discussion.
Ultimâ
This is a bit weird, both are functions of theta (and time) ... so I assume the operator is on both ... is it a case of applying the product rule?
[tex] \frac{\delta}{\delta \theta}(\dot{\theta} cos\theta)[/tex]
I would say product rule looks good.
Thanks for the input, will give it a go
Are you assuming here that [itex]\delta()/\delta[/itex] is a derivative? I would be more inclined to think it means "total variation".
Hi Ultimâ! :smile:
If this is calculus of variations, doesn't [tex]\frac{\delta}{\delta \theta}[/tex] mean that you assume that [tex]\dot{\theta}[/tex] is independent of [tex]\theta[/tex], so that:
[tex]\frac{\delta}{\delta \theta}(\dot{\theta} cos\theta)\,=\,-\dot{\theta} sin\theta[/tex] ? :confused:
It would be nice to think it was that simple tiny-tim, but I fear [tex]\dot{\theta}[/tex] is related to changes in [tex]\theta[/tex] even for small variations. HallsofIvy, I'm not familiar with using the total variation approach, but it is part of a Jacobian so I would assume it was a derivative.
I've just posted the full problem here:
https://www.physicsforums.com/showthread.php?p=1731700#post1731700
(I know cross posting is frowned upon, but I was trying split the problem down into simpler components)
  • · Replies 36 ·
