How can I determine the center of mass of a vehicle?
The discussion revolves around determining the center of mass (COM) of a vehicle, exploring various methods and considerations involved in the process.
  • Participants discuss methods for calculating the COM, including weighing components and considering tire reactions. Questions arise about the necessity of tire reaction calculations and how to find the height of the COM when the vehicle is tilted.
Participants are actively exploring different approaches to find the COM, including weighing methods and the implications of tipping the vehicle. Some guidance has been offered regarding the use of weighing platforms and the distribution of weight across tires, but no consensus has been reached on a definitive method.
There is a focus on finding a general procedure applicable to any vehicle, with concerns about the assumptions made regarding tire reactions and the limitations of measuring individual weights of components.
Altairs
I have to find the center of mass of any vehicle.
These are what I have to make.
Here is what I have thought. I have two solutions :-
1. To find the mass of all the major components and their centers and then equate with the total mass of the vehicle to find the center. My question. Do I need to find the reactions at the tyres ? I don't think so because after all their sum will be equal to the total weight.
2. I was thinking that if I have all the four reactions at the tyres computed directly then is there any way I can find the COM ?
Yes, just think about it for a minute. Picture a flat board with four legs near the corners, now move a weight around on the board.
What would the 'weight' on each leg be if the heavy weight was; in the centre, over one pair of wheels, behind a pair of wheels.
Hi Altairs! :smile:
That will give you the horizontal position of the c.o.m., but not how high it is!
True - although if you tip the car up on two wheels you can calculate the height.
How would I calculate the height ?
But what's confusing me here is that if I take the reactions of the wheels into account and when I'll take their summation then won't they cancel out ? Because the sum of reactions will be equal to the weight of the car.
Altairs said:
… when I'll take their summation then won't they cancel out ? Because the sum of reactions will be equal to the weight of the car.
Hint: don't sum … divide and conquer! :smile:
Right, and what about the tipping part ?
You still divide, and the ratio is still the ratio between the horizontal distances to the c.o.m.
But when the car is tilted, the c.o.m. gets nearer one pair of tyres (horizontally), and so the ratio of the horizontal distances changes. :smile:
Just one useful hint for the tipping part.
Got it. Thanks.
Here is my rough solution. Please suggest improvements, errors and flaws. Especially if you can tell how to shorten this procedure.
Everything is in x-y plane only.
1.First by making FBD and by calculating the individual masses of the components I'll find the reactions at tyres (R1-4).
2. I'll tip the car at front two tyres and will get an equation in x and y. Something like.
W = Weight Of Vehicle
X = Distance in x-axis from the tyres to the C.O.M (when car is horizontal).
Y = Distance in y-axis from the tyres to the C.O.M (when car is horizontal).
L = Distance between tyres 1 and 3 or tyres 2 and 4.
Angle = 45.
Taking moments about the front two tyres (Tyres 1 and 2).
Wcos45 * X = Wsin45 * Y + (R3 + R4)cos45 * L
3. Repeating the same for other two tyres while tipping the car on back tyres (Tyres 3 and 4) will give me another equation in x and y.
4. Solving simultaneously should give the solution.
Hi Altairs ! :smile:
hmm … 45º seems a bit dangerous … wouldn't it be better to use a lesser angle?
Yes, your method seems fine. :smile:
Though you haven't spelt out how you're going to find W.
And I think you need to make measurements on the flat also (and you'll only need to tip the car on one pair of tyres).
(How many tyres can you "weigh" separately and simultaneously? You seem to be planning on separate measurements for two tyres on the same axle, but not for all four, which would be easier, if possible).
(above) Sorry, didn't quite get your point.
45 was just an example.
For W :-
1. I'll sum the individual weights of the engine...etc.
2. I can say that the car was weighed on that big weighing area where they weigh trucks etc.
Yes, the four reactions will be calculated on flat. But I don't see how can I tip the vehicle once and get x and y solved.
Because once you know W, you get no extra information by weighing the car twice at the same angle.
That's because, at 45º say, R1 + R2 + R3 + R4 = … ? :smile:
(and you can get x on the flat, so then you only need y)
Okay. Now I have the whole procedure. I realized that I can find x and z by keeping the car flat and y by tipping it.
Now, the worst problem.
How to find the Rs. I have to give a general procedure for any kind of vehicle. SO, calculating the individual weights of components and then finding the individual Rs isn't an option. Any suggestion ?
uh? I thought you were going to use a standard vehicle-weighing platform?
They're like very big bathroom scales, aren't they?
Isn't it obvious how you measure the reaction on one or two tyres? :smile:
That is what I am going to use to weigh the whole vehicle.
I don't want to use any assumption like equal reactions at all of the four tyres. However, taking equal reactions at the pair of tyres will make things a lot simpler.
I think I need just one reaction. Others, if needed, can be calculated from that one.
If I cannot (which I know I cannot ! ) measure the reaction at one tyre by simply putting that one over the scales than I don't know what to do.
Yes you can … if you put one or two tyres on the scale, and the others on the ground, then the scale will meaure the weight that the scale is supporting.
By Newton's third law, that's equal and opposite to the (vertical component of the) reaction at that point! :smile:
But the problem is that let's say at one time only 1/4 th of the car is on the weighing platform with the front wheels.
Next time, half of the car is over the platform but still only the front two tires are over the platform. Won't the readings change ?
Yes, that's the whole point … the reading only gives the weight supported by the tyres that are on the platform.
So by moving the car around you can find how the weight is distributed between the tyres. :smile:
I am lost.
ok … suppose that when the car is on flat ground, two-thirds of the weight is over the front tyres, and one-third over the back tyres.
If you had two weighing-platforms, close together, you could find this by placing the car so that one pair was on one platform, and the other pair on the other.
Then one platform would show 600kg, say, and the other would show 300kg.
If you only have one platform, you can achieve the same just by putting the front tyres on the platform. Then it will show 600kg. Then turn the car round so that the rear tyres are on the platform. Then it will show 300kg. (Put only one tyre on, it will show half that.)
Finally, you tilt the car by raising the front tyres, and measure, say, 400kg for the rear tyres at an angle of 45º. :smile:
Why turn it around when subtracting reading of front tyres from total can do it?
Why this ?
What I don't get is that this method will only give the ratios of weight distribution amongst the four tyres. What I requre are the 'absolute' values of reactions.
Hi Altairs! :smile:
ah … because then I can add the two weights to give me the total weight of the vehicle.
(I know you want to add the weights of all the components … but I think my way is simpler! :wink:)
I don't follow you. :confused:
Surely the weight on the platform is the reaction? :smile:
I will weigh the whole car on the platform.
But those reactions changes with the position of tyres over the platform. And consequently the COM calculated would change.
But the COM does change if the car is tilted, and the reactions change accordingly, and the weights on the platform equal those reactions. :smile:
I wasn't talking about the tilting operation. The other one, where you said that simply putting the tyres over the platform would give the reactions. What I am saying is that, those reactions will change with the position of tyres over the platform and those reactions would therefor be dependent on the position of the tyres and wouldn't be 'absolute'.
Hi Altairs! :smile:
I'm wondering whether we're talking about the same thing.
What do you mean by "the position of tyres over the platform"?
I've never used one of these platforms, but I was assuming that it didn't matter which part of the platform the tyre was on.
Am I missing the point you're making? :confused:
  • · Replies 25 ·
  • · Replies 17 ·
