Solving Difficult Integral: \int_0^1\ \frac{\arctan(x)}{x(x^2+1)}\ \mbox{d}x
  • Context: Graduate
  • Thread starter Thread starter dirk_mec1
    Integral
The discussion revolves around the integral \(\int_0^1 \frac{\arctan(x)}{x(x^2+1)} \mbox{d}x\), exploring various approaches to solve it. Participants share techniques, substitutions, and insights related to integration methods, including integration by parts and series expansions, while considering the complexity of the integral.
  • Some participants suggest starting with the substitution \(\arctan(x) = u\) to simplify the integral.
  • Others propose using integration by parts, with varying opinions on which function should be designated as "u".
  • One participant mentions using LIPET to determine the choice of "u" and "dv" for integration by parts.
  • Concerns are raised about the integrand \(x \cot(x)\) not having an elementary derivative, leading to questions about the viability of certain substitutions.
  • Some participants express skepticism about the existence of a closed form solution for the integral, suggesting numeric methods as an alternative.
  • References to known results, such as \(\int_{0}^{\pi/2} \ln(\sin(u)) \mbox{d}u\) and the Catalan constant, are made in the context of potential transformations of the integral.
  • Discussion includes attempts to manipulate the integral using series expansions and convergence considerations.
Participants do not reach a consensus on the best approach to solve the integral, with multiple competing views and methods presented. There is uncertainty regarding the existence of a closed form solution.
Some participants note the complexity of the integral and the limitations of the methods discussed, including unresolved mathematical steps and the dependence on specific substitutions.
This discussion may be of interest to those studying advanced calculus, integral calculus, or mathematical analysis, particularly in the context of challenging integrals and integration techniques.
dirk_mec1
Has anyone an idea how to start with this one?
[tex] \int_0^1\ \frac{\arctan(x)}{x(x^2+1)}\ \mbox{d}x [/tex]
Hello Dirk, and welcome to Physicsforums! As for that integral, a good step might be to let arctan x = u, then it makes the integral look much more approachable, you might have even seen it before. Integration by parts is the way to go for that new one.
Thanks!
Okay here we go:
[tex]\int_0^{ \pi /4} u \cdot \tan(u)\ \mbox{d}u[/tex]
Which part, the u or the tangens?
I think the integrand should be u*cot(u), since the x is in the denominator. Also, if you didn't know the derivative of arctan(x), the substitution x = tan(t) (or u) works just as well provided you know trig (it's essentially the same substitution).
I use LIPET (log, inverse trig, polynomial, exponential, trig function) to determine which function should be "u" when you integrate by parts. The natural logarithm takes precedence, and then so on. Since we have a polynomial function, let that be "u" and let the cot function be "dv".
You're right! Are at least the boundaries correctly calculated?
That's clear.
Use LIPET (log, inverse trig, polynomial, exponential, trig function) to determine which function should be "u" when you integrate by parts.
Never heard of Lipet before!
So we get:[tex]\int_0^{\pi /4} u \cdot \cot(u)\ \mbox{d}u = u \cdot \ln( \vert \sin(u) | ) |_{0}^{ \pi /4} - \int_{0}^{\pi /4} \ln(| \sin(u) | )\ \mbox{d}u[/tex]
Assuming this correct how do I proceed?
Yes, the limits of integration are correct. I'm trying to work on the rightmost integral (since that'll solve the problem), but I can't find an easy trick. I know that
[tex]\int_{0}^{\pi /2} \ln( \sin(u) )\ \mbox{d}u = -{\pi}\ln(2)/2[/tex]
because I computed it yesterday, but with the different upper limit of integration, this integral seems even harder. I'll keep trying, perhaps I've overlooked a nice substitution.
Ahh Sorry guys, my very bad mistake :( It seems x cot x has no elementary derivative >.< And the original substitution doesn't have any obvious substitution to me, It must be something nice with the bounds. Sorry again!
Great, what do i have to do now? Series expansion? I don't think there's a better substitution than u=arctan(x), right?
I am just curious, are you sure that there is a closed form solution to this integral?
I have been playing around with it and no matter what substitution I picked I got integrals that are inexpressible in terms of elementary functions (the other substitution combined with change of variable produces x*tan(x)dx).
Perhaps a numeric integration method might work for this.
I think you're right, this integral can not be expressed in elementary functions.
dirk, what is the source of this problem?
Just a buddy pointed out that this would be a 'challenge' (that's why it isn't in the homework section).
I managed to find some info about it but I understand it only to a certain level:
h ttp://mathworld.wolfram.com/AhmedsIntegral.html (remove the space in the beginning)
I am not sure that the integral you linked is related to the problem your friend gave. Where did your friend find it?
Look better! The exact integral is present in the link!
oops, yes you are right.
Deduce the area under the curve= p x cot p from 0 to pi/4.
Perhaps you should have read through the entire thread before posting this. If the upper bound were pi/2, we could have solved it as well.
Sorry, an oversight. Should be Pi/4.
What a mess! Why the answer isn't
ln sin pi/4 {pi/4 - sin pi/4} + 1,
why? Just curious.
I was pondering this integral a little today. I see from the MathWorld site that the solution is
[tex]\frac{\text{Catalan}}{2}+\frac{\pi}{8}ln(2)[/tex]
I think if we are clever enough, we may be able to transform the integral into some other integrals that can be done. Though not by elementary means.
It can be shown that [tex]\int_{0}^{1}\frac{tan^{-1}(x)}{x}dx=\sum_{k=0}^{\infty}\frac{(-1)^{k}}{(2k+1)^{2}}=\text{Catalan}[/tex]
Also, it can be shown that [tex]\int_{0}^{1}\frac{ln(x+1)}{x^{2}+1}dx=\frac{\pi}{8}ln(2)[/tex]
Can we do some manipulations and transform our integral into this:
[tex]\frac{1}{2}\int_{0}^{1}\frac{tan^{-1}(x)}{x}dx+\int_{0}^{1}\frac{ln(x+1)}{x^{2}+1}dx=\frac{K}{2}+\frac{\pi}{8}ln(2)[/tex]
I will have to look at it some more tomorrow. Fun and challenging problem.
I am certain a lot of you out there are certainly better than me at this, so what do you think?.
It is there. I can smell it. I see many different approaches and identities, but am missing something.
I also tried the series for arctan: [tex]\sum_{k=0}^{\infty}\frac{(-1)^{k}x^{2k+1}}{2k+1}[/tex]
If we use that with the rest of our integral, we get:
[tex]\int_{0}^{1}\sum_{k=0}^{\infty}\frac{(-1)^{k}x^{2k}}{(x^{2}+1)(2k+1)}[/tex]
Now, some manipulations here and there and it looks like it should fall into place.
There is uniform convergence from 0 to 1, so we can switch our signs around.
[tex]\int_{0}^{1}\frac{x^{2k}}{x^{2}+1}\sum_{k=0}^{\infty}\frac{(-1)^{k}}{2k+1}[/tex]
If we integrate [tex]\int x^{2k}dx[/tex], we get [tex]\frac{x^{2k+1}}{2k+1}[/tex].
Which when multiplied with the other 2k+1, we get the catalan constant.
Like I said, it is right there, but.....:rolleyes::biggrin:
I am just throwing some things out there. Having fun with the problem.
  • · Replies 27 ·
  • · Replies 20 ·
