Thread Closed
translation and rotation
Share Thread Thread Tools
May30-08, 03:56 PM   #1
Heres the diagram for the problem...
http://img78.imageshack.us/img78/3248/35090397eg3.jpg
heres my work...
http://img141.imageshack.us/img141/8352/33iw6.jpg
I made my conversions.... im starting by finding the speed at D.....its not zero because of the angular velocity.....but Im trying to figure how to add the two x components...
the translational x component should be .833 ft/s......but for the rotational I need to account for omega.....
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
May30-08, 04:51 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
What's the rotational speed? Is that the problem? It's r*omega. So that's the rotational speed. Now just split the velocity vector into xy components. This is basically an identical problem to you last post.
May30-08, 04:52 PM   #3
And what is the question?
May30-08, 04:57 PM   #4
Recognitions:
Quote by kamerling View Post
Good point. In the last post is was to compute the velocities at the various points.
May31-08, 10:25 AM   #5
The problem is asking for the velocity at points D and B...as well as if the object is slipping.....Im still trying to figure out point D first
May31-08, 10:32 AM   #6
ok I found D....it was just the rotational - translational ....
I used the V=r*omega to get the rotational
[tex] V_{d} = .999 - .833 = .166 ft/s = 2 in/s [/tex]
but actually I think the signs should be reversed if you look at the vectors in my FBD...that makes sense because the magnitude is the same and the direction should be to the left which is negative...
May31-08, 10:49 AM   #7
ok I found the velocity at point B as well.....im just not sure how to tell if the wheel is slipping or not...
May31-08, 10:56 AM   #8
Recognitions:
If the velocity at D is non-zero, then it's slipping. If it's not slipping then point D is moving at the same speed as the road and has zero velocity.
May31-08, 11:27 AM   #9
Thank You...thats what I thought....
Thread Closed
Thread Tools
Similar Threads for: translation and rotation
Thread Forum Replies
[SOLVED] Rotation and Translation Introductory Physics Homework 11
translation/rotation Introductory Physics Homework 17
Need help combining rotation and translation Engineering, Comp Sci, & Technology Homework 2
Translation/Rotation Differential Geometry 2
Dominoes: Translation and Rotation Classical Physics 5
