Thread Closed
ions in water - what does ppM actually mean?
Share Thread Thread Tools
Jun1-08, 05:53 AM   #1
"A Copper test is performed much as you would test for chlorine residue. A level of copper in the range of 0.15 through 0.20 ppM"
The above is an extract from a page on swimming pool ionisers. The ionisers produce copper ions for water cleaning purposes.
0.2ppM (parts per Million) - I don't understand how you can quantify copper ions in this way. Is this a ratio by weight? or does it man 1 atom of ionised copper per 5 million water atoms.
Any thoughts on the actual meaning of this appreciated.
What I'm really looking for is an idea of how much copper I need to electrolyse to prevent algae growth.
I am attempting to construct a simple ioniser for a small decorative fountain we have. Currently we use chlorine tablets but that kills the surrounding plants which get splashed - and more importantly displeases 'she who must be obeyed'.
Bitman
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Jun1-08, 06:19 AM   #2
Recognitions:
Homework Helper Homework Help
IIRC from high school chemistry, using Avogadro's number you can convert particle numbers into moles. Then you can turn the ppM quantities into molarities.
Jun3-08, 02:10 PM   #3
I would imagine that this is based on weight (mass). Rarely have I seen it based on number of atoms.
Then, 0.2 g Copper per (10^6) g H2O = (0.2/1000000)= 2*(10^-7) Wt %
MW Cu = 63.5 g/mol
MW H2O = 18
Then, .0000002 * (18/63.5) = 5.67*(10^-8) Mol %
Jun4-08, 02:59 AM   #4
The question is not as trivial as it might at first seem. It could be by volume (tricky for gases with changing pressures), by mass, by atoms as I suggested earlier. As any of these will yield different results it seems a pretty arbitrary thing.
Bitman
Jun4-08, 02:50 PM   #5
Indeed it can be arbitrary, but usually for liquids it is on a mass basis, and for gases it is on a volumetric basis. Personally, I would go with this assumption first because it seems the most reasonable.
Thread Closed
Thread Tools
Similar Threads for: ions in water - what does ppM actually mean?
Thread Forum Replies
Which pair of elements is most apt to form an ionic compound Chemistry 4
Alkyloxonium Ions and water Biology, Chemistry & Other Homework 1
Which ions? Chemistry 14
H- and HII ions Astrophysics 2
air ions Classical Physics 2
