How Does Internal Resistance Affect Terminal Voltage in a Circuit?
The discussion centers on calculating the terminal voltage of a torch battery with an emf of 6.0V and an internal resistance of 1 Ohm when a load of 0.5 A is applied. The terminal voltage can be determined using the formula V = E - Ir, where E is the emf, I is the current, and r is the internal resistance. In this case, the terminal voltage is calculated as 6.0V - (0.5 A * 1 Ohm) = 5.5V. Additionally, participants are encouraged to mark threads as "[SOLVED]" once their queries are resolved to assist others in the forum.
  • Understanding of electromotive force (emf)
  • Knowledge of internal resistance in electrical circuits
  • Familiarity with Ohm's Law
  • Ability to perform basic electrical calculations
  • Research the impact of internal resistance on battery performance
  • Learn about different types of batteries and their characteristics
  • Explore advanced circuit analysis techniques
  • Study the effects of load on terminal voltage in various electrical components
Students studying electrical engineering, hobbyists working with batteries, and anyone interested in understanding the principles of voltage in circuits.
Libra_girl
A torch battery has an emf of 6.0V and an internal resistance of 1 Ohms. What is the voltage measured by a voltmeter connected across the terminals of the battery, when the battery is connected to a bulb that draws 0.5 A from the battery?
Anyways thanks I solved it.
For future reference, if you're satisfied that you've figured out the problem and are satisfied with the answer, edit your thread title to include the word "[SOLVED]" at the start of it. This will let the helpers know that you're all right and they won't need to open your zero-reply thread. Thanks!
  • · Replies 105 ·
14K
  • · Replies 58 ·
  • · Replies 22 ·
  • · Replies 21 ·
